Another 1984 VF500F project
Discussion in '1st & 2nd Generation 1983-1989' started by rcthirty, Mar 2, 2025.
    Were your other carbs also vented to the plenum (long, oval, gold colored plate in the center of your second pic) and not atmosphere? That's basically what I'm verifying, but I would also like to know their numbers.
  2. rcthirty
    rcthirty New Member
    You mean the gold colored throttle plates ? If so no, those carbs were replaced with throttle bodies with the silver plates. All are silver plate.
    No. In your second pic (post 116) looking down on the carbs in the center, 1 screw in it...
    "(long, oval, gold colored plate in the center of your second pic)"
  4. rcthirty
    rcthirty New Member
    Oh that plate. The original carbs were just like that. They had the plate. Only one carb was replaced and its the same.
    Captain 80s likes this.
  5. rcthirty
    rcthirty New Member
    On another note. I'm about to install the coils but the spark plug caps are pretty bad. Wires too. Anyone know of where to source replacement caps or wires ?
    I buy NGK caps and bulk NGK wire. But the wires are VERY resilient on Hondas. You can trim back about 1/8" and install new caps. The caps are available straight, bent and 90 degree.
    Usually eBay or Amazon for me after figuring what I want and a thorough search for a good deal.
  7. rcthirty
    rcthirty New Member
    The caps are not like my other VF500. These are straight so it makes it easy. I'll look into what's available. Thanks Captain !
  8. rcthirty
    rcthirty New Member
    I found these on Amazon. Although they are automotive the caps look right and the length of the longest one is 30" which is what I need. Do they look ok to you Captain ?
    Keep in mind that you will be eliminating the ends to the coil. I personally would make sure they are a stranded wire core like the originals.
    Also, you may not want a straight cap on the front cylinders going straight into the radiator, but there may be plenty of room. I prefer the XD05F.
  10. rcthirty
    rcthirty New Member
    Thanks. Great idea . I'll look into these.
  11. rcthirty
    rcthirty New Member
    I have the wiring harness installed and most wiring complete. I need to wire the speedo gauge and it's components.
  12. rcthirty
    rcthirty New Member
  13. NuggyBuggyVFR
    NuggyBuggyVFR New Member
    @rcthirty - this thread and your other thread make me sad and discouraged - because I realize how I will never get my own project to a state one thousandth as nice as you did yours!
    wonderful work but I really should just pack up mine.
  14. RogueRC24
    You never know, the moto gods could shine down on you at any moment. :)
  15. rcthirty
    rcthirty New Member
    I'm retired and have a lot of time on hand. That's why I can tinker on my projects so much. Any restore on a vf500 is a good one.
  16. rcthirty
    rcthirty New Member
    I received the battery from amazon . The same one I have in my other vr500. I had to do a lot of modifications to the battery box to make it fit . Battery installed.jpg
    Jim McCulloch likes this.
  17. rcthirty
    rcthirty New Member
    My progress has come to a stop as I can't seem to get the shifter assembly installed right. When I turn the drum manually it shifts fine but as soon as I put it all together it won't shift. Once I get this sorted out I'll post an update.
  18. rcthirty
    rcthirty New Member
