Any riders from Ireland around?
Discussion in 'Europe' started by CamelVFR, Mar 9, 2009.
  1. 02 VFR Rider
    02 VFR Rider New Member
  2. Steed
    Steed New Member
    Meath
  3. Steed
    Steed New Member
    Meath
    Just did a quick browse of the videos available to watch on this Isle of Man TT website. Check this link out YouTube - Steve Hislop - On-board. Are these guys totally insane or what ? How do they do this , incredible stuff.
  4. Rambo
    Rambo New Member
    Cavan man living in Dublin, bought me mates VFR fiy 2000, cleanin it up at mo for 2011
  5. professore
    professore New Member
    Cork
    I'm down in Cork just bought a 1997 VFR 750
  6. roryforde
    roryforde New Member
    is this thread dead..? anyone out there...? helllloooooo....
  7. barry91
    barry91 New Member
    Any can help me my vfr400 is making a clicking nose from starter relay but won't start
    Sent from my HUAWEI Y300-0100 using Tapatalk
  8. barry91
    barry91 New Member
    Vfr won't start clicking nose
  9. barry91
    barry91 New Member
    I'm from cork
  10. Allyance
    Allyance Insider
    Germany
    East Bay, California
    If relay is clicking, usually means battery is weak, enough to operate relay, but not starter.
    Age of battery? Check connections for corrosion, not enough charging current?
    If problem persists, recommend posting thread in Mechanics Forum.
  11. barry91
    barry91 New Member
    New battery and full charge
  12. Allyance
    Allyance Insider
    Germany
    Starters require high current. Relay closes heavy duty contacts that can carry high current. Separate heavy wire from battery to starter to crank starter. One of three things: relay is bad, not passing high current; or starter motor is bad; or wiring is corroded not passing current. Need to check with volt meter to find where voltage stops.
  13. barry91
    barry91 New Member
    Thanks will try dat
  14. Allyance
    Allyance Insider
    Germany
  15. barry91
    barry91 New Member
    Any idea how to remove starter
  16. Allyance
    Allyance Insider
    Germany
    From Google, your starter relay. Check 30 AMP Fuse, if you can get a clean shot at the terminals, try using an old screwdriver and short them out (like closing relay) if starter works, then it is the relay. Make sure no gas fumes around!
  17. barry91
    barry91 New Member
    Ya tried bat starter turns but won't start. bike is doing my head in
  18. roryforde
    would agree about the battery; had a VFR 750 with an old battery; when it went bad the symptoms were similar to that, but I ignored the battery; ended up going thru 2 reg/rec and tracing down some burnt wires and connectors (as well as finally replacing the battery). Lesson learned.. when things start to go funny, suspect the battery from the start..
  19. barry91
    barry91 New Member
    Battery is new
  20. Steed
    Steed New Member
    Meath
    Yeah I,m still here , Can't speak for anyone else though.
