Anyone ever used Motul "MoCool", instead of Engine Ice? 30f lower run temps
Discussion in 'Mechanics Garage' started by havcar, Mar 8, 2011.
  1. havcar
    havcar New Member
    Denver CO
    As part of the spring/summer prep, I'm doing a coolant flush and I thought I would try MoCool. Motul states that distilled water, with 5% MoCool added, will work as coolant and drop operating temps by as much as 30f. I'm a little skeptical, so I thought I'd see if anyone has any experience with it.
    http://www.motul-oil.co.uk/pdfs/coolants/MoCool_TDS_(GB).pdf
  2. rc24rc51
    rc24rc51 New Member
    Liberty SC
    Does it offer freeze protection as well?
  3. jake691980
    jake691980 New Member
    Wilmngton , North Carolina
    not according to the link he posted it would be nice if it did. But it did say that it could be added to most coolants that are monoethyleneglycol based.
  4. jake691980
    if you end up trying try to remeber to post and tell us how it worked.
  5. squirrelman
    Maintain your skepticism cuz that claim seems unrealistic.
  6. wheelywong
    wheelywong New Member
    My bro just put this in his R1. He says it runs about 5 Celsius cooler than the normal running temp out on the flowing road. But still gets up there enough to turn the fan on in traffic. ie 104c+ So yeah not really worth the effort and cost unless you have to do a cooler change. But if you have problems with your cooling, it's not going to fix it.
  7. rc24rc51
    rc24rc51 New Member
    Liberty SC
    So it's really similar to Water Wetter.
  8. havcar
    havcar New Member
    Denver CO
    ^^ That's correct, if not an improved formula. I will still need to use an anti-freeze. Even if the temp drops are closer to 10f-15f then I think it's worth trying; that would keep the bike below 210f during most redlight situations, and hopefully somewhere in the 180's while moving. I'm doing the flush on Fri and will report back on warm-up times and running temps as soon as I have an opportunity to ride in warmer weather.
  9. GuitarX
    GuitarX New Member
    Denver Area
    Just buy an MV and the VFR will be the coolest running machine in your garage. Problem solved!
  10. havcar
    havcar New Member
    Denver CO
    ^^ True that! Maybe next week.
