Anyone have a pipercross airfilter on their fifth gen?
Discussion in 'Mechanics Garage' started by Cessus, Oct 29, 2015.
  1. Cessus
    Cessus New Member
    SW VA
    I got a pipercross airfilter for my fifth gen, Upon recieving it and trying to fit it into the airbox I've discovered its the same shape of the airbox but the rubber edge is very slightly too thick in places and the whole filter can't completely seat into the airbox. I've read on other forums that they recommend just center it as best as they can and screw the airbox lid down onto it. Anyone have any experience with these?
  2. V4toTour
    V4toTour New Member
    uh, oh.. I can already see where this thread is heading. Someone get the cat litter ready.
  3. RVFR
    Is this a place for maybe wd-40 or KY jelly.. just saying.
  4. 34468 Randy
    Made me kinda snort out loud! Embarrassing.
  5. 34468 Randy
    Well. I guess, so long as there is a tight seal, everything else fits, and there is no air bypassing the filter, then go for it. But you bought something that is supposed to fit your bike and it does not. I would be taking it back. MHOFWIW.
  6. RVFR
    The talk is they're a great filter Hmm??????
  7. 34468 Randy
    As far as filtration goes, maybe they are the best. I just don't know J but if they are being sold to fit our bikes, and they have a documented problem, why not fiddle fart with that mold a bit and make a proper fit?
  8. sunofwolf
    sunofwolf New Member
    pipercross = chip monk food!
  9. V4toTour
    V4toTour New Member
    It's kind of like Mad Libs.
    "pipercros makes best air filter. more horsepower over stock one q gave bond in all his cars. a1 burger from BK turns poops green, denso plugs more power. I take vfr down road, cold auttum air means mor power more oxygen, breaths easy. didn't drop, air pressure was low tomBrady must of worked on bike .:chaingun: special 1 qt blend of stabil, seafoam oven clean + CLR makes viffer run like purring kiten. trvelocitgy has cheapest air fair. Black hole sunWon't you comeAnd wash away the rain. don't shop at petsmart no more. vanilla coke. :triumphant:"
  10. OOTV
    OOTV Insider
    Although I don't have the piper cross, I do know that the K&N filters actually require that you remove the o-rings of the air box lid. There is a lip on the filter edge an that fits inside the area where the o-rings used to sit. If you need a picture of what I'm talking about, I think I might have one somewhere, otherwise I can probably take one sometime tomorrow.
  11. Cessus
    Cessus New Member
    SW VA
    I did shape the rubber a little bit using a blade. Got it to fit snuggly. Have noticed a difference in throttle response and power in upper rpms seems to be a bit smoother as well. I got this for 25$ shipped new from a shop on ebay. Definitely better then the pos chinese filter I accidently ordered which I thought was oem and was refunded on.
