Are you?
Discussion in 'Anything Goes' started by RVFR, Mar 13, 2008.
Key or Kill? How do you turn your bike off?
  1. Turn the Key
    66.9%
  2. Use the Kill Switch
    36.1%
  3. Leave it in Gear
    25.6%
  4. Put it in Neutral
    37.6%
Multiple votes are allowed.
  1. hondawolf
    hondawolf New Member
    Livermore, Ca
    Key off, in gear on side stand. Almost never use the center stand. Mainly worried someone in a parking lot might somehow bump the bike from behind, and knock it off the center stand.
  2. powerslave
    powerslave New Member
    winnipeg,manitoba.
    Usually kick down the stand to shut 'er off,then remove the key and I always leave it in gear.
    I so rarely use the kill switch that when "somehow" it gets flipped open I get a panic attack when my bike won't fire up right away!
  3. tbones86
    tbones86 New Member
    N/W Central Wisconsin
    off w/ key in neutral w/ side stand; if parked on hill in gear w/ tail end leading down hill against a curb.
  4. grinder
    grinder New Member
    British Columbia, Canada
    Key, neutral usually but if I think there is any chance of rolling in gear.
  5. NeverlosT
    NeverlosT New Member
    Narragansett, RI
    I usually just do the sidestand in neutral when riding, and the centerstand in neutral when at home. I should get in the habit of leaving her in gear on the sidestand on hills at least.
    As far as the kill switch or key, I do 50/50, but yes, I also have a small heart attack each time i try and start her up and nothing happens...cause the kill switch is on...
  6. jerry 1 a b
    jerry 1 a b New Member
    <---What he said.
  7. eleman
    eleman New Member
    Hudson, IL
    I use the kill switch and then turn the key off. I usually put it on the center stand because I thnk it is more solid. I will leave it in gear if it is on a hill and I use the kick stand because the center stand leans to one side too much.
  8. MarkBartels
    MarkBartels New Member
    Key off, neutral unless on a hill.
  9. PARedVFRRider
    PARedVFRRider New Member
    Skippack, Pennsylvannia
    Well I always kill the engine with the kill switch. When I park it everywhere other than my garage I pop it up on the center stand and leave it in neutral. However, in my Garage I have a Baxley Sport Chock that I ride the front wheel into and I leave it in 1st when I do that to keep someone from accidently yanking it out of the chock. I put that keeper lock on the Baxley but I'm not overly confident that would keep the bike in the chock if someone sat on it and rocked it backwards.
  10. Ghost 1
    Ghost 1 New Member
    Germany
    A man after my own heart! I love doing that to my friends at stoplights!
    I always Kill Switch it first. Don't know why.
  11. rngdng
    rngdng New Member
    Goose Creek, SC
    I can't believe you're discussing this.
    What kind of underwear do you like? Do you prefer Kotex or Tampax? Do these leathers make my ass look big?????
    Lane
  12. jasonsmith
    jasonsmith Member
    Vancouver, BC
    Ditto :nod:
  13. RVFR
    Yo, thanks to whom set up the poll, good form :wink:
  14. pontiacformula99
    pontiacformula99 New Member
    Smyrna, TN
    Just let off the clutch in 3d gear, then switch, nuetral, key, battery, vice grips on the fuel line... Gotta be sure no one runs off with it:nono:
  15. Tori
    Tori New Member
    Grover Beach, CA.
    I have always used the key. All the Honda owners manual tell you to use the key also.
    I happen to know someone that uses the switch,.... don't ask how many times we've had dead battery/push start him.
  16. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Killswitch, then key, leave it in first.
    Unless I am jumping it up on the center stand, then neutral.
    BZ
  17. reg71
    Sikeston, MO
    can I vote on this? Is it SLOVFR? is it...is it?
  18. PuCaudata
    PuCaudata New Member
    Great Falls, Montana
    Nicely played, rngdng :cool:
  19. Nepix
    Nepix New Member
    Seattle, WA
    killswitch then key and neutral, then I can let it warm up again without changing gears in the morning
  20. xShadowrider
    xShadowrider New Member
    Fenelon Falls, Ontario, Canada
    Key, 1st gear, side stand unless at home then it's in the garage, key, centre stand, neutral, cover, pat on the ass.
