Attempted VF1000F2 resurrection
Discussion in '1st & 2nd Generation 1983-1989' started by Waylander, Jul 5, 2020.
  1. Waylander
    Waylander New Member
    Waltham Abbey, Essex, UK
    Managed to find a good set of original exhausts, advertised as VFR750, incorrectly
    Paid $50 for them, hardly rusted at all
    VF1000F2F, in bits
    jstehman and Viffer J like this.
  2. straycat
    Wow, nice find on the pipes !!!, you stole them.
    Bike looks fantastic !!
  3. Waylander
    Still needs some cosmetic stuff, but the engine is quiet no rattles or tappets
    Clutch and gearbox much improved after oil change
    Need a new rear tyre, going with a Conti- Motion, and I think I need a puncture or something fixed in the front
    I have new decals for the seat tail unit, just waiting for it to warm up a bit
    Still lots of cleaning to do
    VF1000F2F, in bits
    That my friend, was a score. Nice!
  5. Jim McCulloch
    Jim McCulloch Member
    VERY nice score!
  6. Waylander
    I have another set I got for $40, the front ends are rotted off, but my mate who is a genius TIG welder is putting some new ends on them
    I will sell those, and sell the Lasers,
    VF1000F2F, in bits
  7. Waylander
    New decals applied to the newly painted seat tail
    VF1000F2F, in bits
    Captain 80s and sixdog like this.
  8. Waylander
    I have discovered what is causing the front tyre to deflate, whatever twonk fitted the front tyre, has managed to rip the rubber base of the valve, now going to have to see if I can replace that
    VF1000F2F, in bits
  9. Hellapet
    Hellapet New Member
    Media, PA
    Hi Waylander, this thread has been a joy to read. Would you care to share your windscreen polishing techniques? The bike looks amazing and that glossy screen makes a big difference.
  10. Waylander
    Hi
    The screen was a machine polish job
    First job was a gentle clean with a smooth clay bar, to remove the lumps and bumps, then the glue removed with a scalpel blade
    Then gently polished with a 3” orange hexlogic cutting pad, with megs 105, when I was happy that I had removed the worst, I finished it off with a white hexlogic pad and megs 205,
    Managed to find a new old stock screen edging finished it nicely,
    You can still see lots crazing in the plastic but that’s just age and can’t be fixed
    VF1000F2F, in bits
    Hellapet likes this.
  11. Waylander
    I think I have found another tank in silver, another top half of plastics,
    Another pair of genuine exhaust cans, and a few other bits, going to collect Thursday
    VF1000F2F, in bits
  12. Waylander
    Ok so I wanted to do this without removing the wheel or tyre
    The busted valve stem[​IMG]
    Here we go
    Bit more and I’m in[​IMG]
    Nice new one
    Took less that 30mins
    VF1000F2F, in bits
    jstehman likes this.
    Holy shit, nice hack.
  14. Diving Pete
    now you have done it, I would replace it with a small height one - makes inflation & checking really easy... I can send you one or if you take the wheel off & bring it to me I can change it.. Im very close to Jct 4, M4
  15. Waylander
    Ah it was a case of use what I could get at short notice
    Funny thing is I bought it from a motorcycle shop, I can get the tyre pump on it easy without bending the valve
    VF1000F2F, in bits
  16. Diving Pete
    ok, its just I replace all mine for the low height & have plenty spare..
  17. Diving Pete
    I think you have the TR414 - I have those for car wheels & the TR412 for my bikes.
  18. Waylander
    I can change it again, I have a rear tyre to change as well so I will order some
    VF1000F2F, in bits
  19. Diving Pete
    just ck they are not the Mid height TR413... - they actually are a pretty good size too.. so perfectly usable on a bike.
  20. Waylander
    So on to the next problem
    Seems the damping adjustment on the rear shock is a wee bit stiffer than it should be, moves about 6-8mm thats ya lot
    Now I’m not going to go buy a YSS or Hagon unit, I would like to try and fix the one on the bike
    So I’m open to suggestions on how to go about fixing the adjuster, the cable is free moving
    VF1000F2F, in bits
