Attempted VF1000F2 resurrection
Discussion in '1st & 2nd Generation 1983-1989' started by Waylander, Jul 5, 2020.
  1. Waylander
    Waylander New Member
    Waltham Abbey, Essex, UK
    Looking at that link, it’s going to have to be a couple of elbows and a pump with straight necks,
    But I do like trying to fix stuff, so one of these two knackered ones will be coming to bits, and have it’s insides replaced with the guts out of a straight pipe one I bought for $14 off the bay of fleas
    VF1000F2F, now rideable,
  2. Waylander
    Went to Kempton park auto jumble for motorcycles
    Nothing of real interest except a set of fully cleaned VF1000F carbs for £80
    Didn’t buy them as I have two sets
  3. Diving Pete
    Did you just visit the show or also put a bike in the display.
  4. Waylander
    It’s not any kind of show, just crate and crates of rusty parts for old British bikes, I
    won’t bother going again
    Something my brother and I have chatted about doing for years, now he’s got terminal cancer, we are doing lots of these odd things
  5. Diving Pete
  6. RllwJoe
    RllwJoe Member
    Sorry to hear of your bother's diagnosis. Nothing like the brevity of life being thrown in your face to force you to get your prioities in order. You are a good man to prove to him that he is valued and I'm sure that you will not regret the time and effort given to do so.
  7. chuntera
    chuntera New Member
    Connecticut, USA
    If you go with the solid state fuel pump, get one with a "positive shut-off valve".
  8. Waylander
    I have found a non working VF1000 pump on the bay of fleas
    Just needed the broken points wire fixing, and it’s working and not leaking
    Going for a test ride today, if it don’t rain
  9. Waylander
    I have been whizzing about on it for a bit, not too far from home incase it packs up again
    But I have noticed a lot of clutch noise, a sort of chattering that goes away when I pull the lever in
    Could someone possibly provide some insight if it’s possible to shut it up
  10. Jim McCulloch
    Jim McCulloch Member
    Sounds like me when I go the 500 running. Only rode as far as I felt like pushing the bike back LOL.
    I am sure someone here knows the cure to your malady.
  11. Diving Pete
    Noisy clutch basket would be my guess.
  12. Waylander
    Yep guessed as much but what’s the fix, is it worth doing or just let it rattle
  13. Diving Pete
    well for the sake of a gasket - have a look. It won't make it worse !!
  14. sixdog
    I would say you need to sync the carbs....
  15. Waylander
    Done that little fun job, but they have been apart a few times so they might be out of whack again after a settling down period
    It floods and smokes a lot on choke so they are probably blocked up again
  16. Terry Smith
    My VTR1000F had a noisy clutch at idle, so I whipped it out for a look-see. The only thing I found was the clutch damper springs were surprisingly slack and probably the source of the noise. The rest of the clutch (plates and basket) were mint (76000km) so I buttoned it all up and put my mind at rest.
    This is what the clutch sounded like when I had it out
  17. Waylander
    Being an F2 Bol, taking the dam fairing off again, I always seem to break a bit
