Attempted VF1000F2 resurrection
Discussion in '1st & 2nd Generation 1983-1989' started by Waylander, Jul 5, 2020.
  1. NorcalBoy
  2. Waylander
    Waylander New Member
    Waltham Abbey, Essex, UK
    Thanks guys,
    I don’t really have a go to place for parts, this is the first motorcycle I have looked at in 22 years
    Just waiting for vinscoot to confirm, and also been in touch with another seller on eBay pipeman who sells these
    As the F2 was not sold in the US they are not sure what will fit correctly, as they don’t have a pattern to work from,
    I will have to get something sorted soon as I’m attempting to get it through the road worthy test on the 4th August
    Simply using the link that NB provided and cross referencing provides the answer that they are the same as many U.S. models. You should be able to get them to put together a proper kit.
    Parts Search Results
    Assemblies where 16022-MB1-771 is used
    Assemblies where 16026-MB0-671 is used
    Assemblies where 16027-MB6-671 is used
    Assemblies where 16047-KE7-003 is used
  8. Waylander
    Wow, thanks very much
    I will get some pipes ordered, I have now been ordered to get on with the next room for decorating, by the management
    I will squeeze some bike time in the evening
  9. Waylander
    While I’m waiting for parts and other things, I thought I would take a look at removing the horrid LED indicators and put the standard ones back on, started following the wiring trail, and
    The big black lump with all the red and blues coming out, is some kind of electronic led driver, you can just see one of the indicators in the yellow wire loop at the top.
    Really don’t suit the bike, far too modern
    As you can see I’m working in a cramped space at the rear of the garage, stuck behind the Mrs Mercedes SLK320 she never drives
    That black lump could be the resisters that help LED markers flash at a normale rate. LEDs can be plugged in as normal, but just flash much faster.
  11. Waylander
    I can see some electrical surgery is going to be needed
    I have got my brother to order a set of pipes from vinscoot (Dave) for a VF1000 R, these should solve my issues, and then I will have 3 plastic ones to sell off.
    Still waiting for some delivery’s, in the wait I have taken some pictures of the inside of the tank before it gets the Deox-C treatment
    So before .......
    The top of the tank is much worse than the bottom,
  12. Waylander
    The Deox-C has arrived this morning
    Mix this 1kg pack with 20litres warm water
    Seal fuel float hole
    Syphon contents of bucket into tank
    Now leave fo 24 hours, rinse and repeat if needed
    You can use this stuff over and over till it goes black, then chuck it away
  13. Waylander
    Well the results are half in
    Need to turn it over now
    Not quite deep enough, but all the rust gone
    I have blocked the fill hole and half refilled it
  14. straycat
    That stuff works really well!!
  15. Diving Pete
    I have a bottle of that ... guess what’s my next job lol
  16. raYzerman
    raYzerman Member
    Millgrove, ON
    Impressive that! Fortunately, I've never had to do it... filed away in my data bank, thanks.
  17. Waylander
    The last bit of rust by the inside of the filler
    Think I’m quite happy with the results
    Now to put the hose pipe in and wash it out, put some light oil in there to stop any further rusting till it’s back on the bike
  18. Waylander
    So not much done, you were quite correct captain 80’s, It was a pair of big resistors, can you believe wrapped in shrink wrap, then a layer of aluminium foil? Then another layer of shrink wrap
    Removed all that, and fitted the rear originals, then came to take a look at the fronts, looks like both mountings are broken out the fairing, and the plates that fit in the fairing are both broken, now have to work out how I’m going effect a decent repair keeping looking fairly original
    The lower half of the fairing is also very battered and broken, think I might have a big task on my hands with the fairing
  19. Waylander
    I have repaired the little teardrop shaped parts that hold the front indicators, these are ABS which is great news as it’s easy to fix
    Hope the fairing is the same stuff, if so I will have to go buy a load more Lego Bricks
  20. raYzerman
    raYzerman Member
    Millgrove, ON
    Permatex Plastic Epoxy is great stuff as an alternative to Legos, very tough, fileable, sandable, paintable.
