Attempted VF1000F2 resurrection
Discussion in '1st & 2nd Generation 1983-1989' started by Waylander, Jul 5, 2020.
  1. Waylander
    Waylander New Member
    Waltham Abbey, Essex, UK
    So my spare bike looks like it’s an F,
    Discovered the engine is not seized and it turns over ok, so I have a spare Engine that has done on 20k
    Mains are 110 all round
    VD86A
    Now I'm starting to get really good at getting these off and back on, so is it worth changing the jets to all 110 to prove the point, cos at 162 the ones in there are 40% bigger
    VF1000F2F, in bits
    If you feel like the work, the 110 should show the bike was over jetted. The 110 might be small for wide open pulls, but you should be able to approach the upper RPMs. I think 118 to 120 will be your sweet spot with stock mufflers and airbox.
  3. Waylander
    The cans are Laser, stock pipes fell apart years ago I think
    I can do a get swap in about 30 mins, I’m getting good at this
    And there is no place round here to do wot runs plus I don’t think my heart could take it, nor the 13 year old rear tyre
    VF1000F2 a work in progress
    Report back then. Consider going up on the pilot jet (#40) too if you end up ordering jets. All the VFs like it, even completely stock, they were jetted lean on the idle circuit.
  5. Waylander
    It wont be today, too busy with work, and grandson to soccer tomorrow, so possibly sunday afternoon,
    But I have managed to get some genuine mirrors, black but good enough to look at my arms all the time
  6. Waylander
    Well got home early from soccer, and managed to find some time
    Whipped the carbs half off and popped in the 110 jets, well that’s fixed it
    It now revs right up to the red line, feels a little flat as it goes through the 6k then takes off like a scolded cat
    How the hell do you get to the balance screw between 4 and 3, I have a 90 degree adjustment driver, but just can’t find a way in there
    But it’s all good!
    VF1000F2F, in bits
    Terry Smith likes this.
  7. Diving Pete
    AWESOME !!!!!!!
  8. Diving Pete
    Still think if you change them to 40 pilots, 120 / 125 mains you will be dancing on the ceiling...
    Great news
  9. Waylander
    Think I will just be happy in the fact that I have fixed it, for a while
    I have more than enough of taking carbs to bits, the mrs moaning I stink of V-power, the carbs off the spare bike are in a state, but the diaphragms are like brand new, so I think I will swap those over changing the needles as I go, as I have not yet found reference as to what they should be and if I can even read what they are
    I do think it vibrates quite a lot so that’s possibly a carb balance issue, but then I don’t have any experience of any other VF to compare too
    Be good if another owner could give it a blast and let me know if it feels ok
    VF1000F2F, in bits
  10. Diving Pete
    fyi - you do not need V-Power - once in a while is fine, but its not like you need the octane boost. Before I winterise my bikes i put V-power in a week before and run it a bit to ensure thats the fuel in the system... Then away they go --- lol
  11. Waylander
    No ethanol for me thanks,
    For the limited mileage the extra cost does not come into it
    VF1000F2F, in bits
  12. Diving Pete
    its not the cost - your bike was only designed for 91 octane. You just don't need to use it normally.
    Great news! Yeah, take a break I suppose. But the sooner you dive back in, the easier it seems. :)
    Check all your motor mount bolts and the bolt on the side of the exhaust collector that mounts to the motor.
  14. Waylander
    Interesting, as the lowest octane in the UK is 95?
    Standard unleaded is 95, V-Power is 98, and sometimes I take the Porsche to the local airfield and buy a gallon or two of avgas 102 octane, helps get the cobwebs out
  15. Waylander
    Thanks for that idea, I will consult the manual and re-torque them up
  16. Diving Pete
    And thats the reason you don't need 98...
    The bike was designed for many markets - & so you can be confident it will run on almost anything... - don't try diesel though - lol
  17. Waylander
    So forget all that nonsense, I have the sealey 110 bent carb tool, just can’t get near the adjuster between the front two carbs, is there some kind of trick to it?
    I can get to the two rear balance adjusters easy enough,
    But the front just defeats me
  18. Diving Pete
    Another way is a pair of garden gloves & a stubby flat head screwdriver. But you do get burnt - lol..
    Note: I also have the sealey 110. It sometimes has its uses but isn't as good as you might think HOWEVER there is an answer for you.
    After failing with the Sealey I went and bought this.
    http://www.carbtune.co.uk/bevel.html
    It made all the difference & I wish I'd bought it years ago. It's precise & the different heads make it easy to use. I normally use a different length on the front pair.
    No longer burnt hands made it worth the cost.
  19. Waylander
    Me Again,
    as it has not stopped raining for 4 days, I thought I would take a look at the brakes, for one thing they were not really awe inspiring even after a change of fluid which was 11% water
    I had a quick look today before taking them to bits and having a very good inspection popping the pistons and a good clean, after having fluid like that in....
    anyway they appear to have brand new pads and pins and other bits in, but the pads I think are Gold Fren, never heard of them! so my next question is are they crap, is that why the brakes do not feel brilliant, and if so what's the recommended
    Always been a fan of Brembo brakes are they any good on these stainless steel disks
  20. squirrelman
    ^^ brand new pads need some bedding-in miles b4 they start to work better.
