BabyBlade
Discussion in '1st & 2nd Generation 1983-1989' started by linkken, Nov 1, 2024.
  1. linkken
    linkken Member
    Fortine, MT
    All ready to ride (except for road conditions)...
    I TRIED to take the Superhawk for a little ride yesterday to see if my road was passable, NOT! (another story) but the main road was fun.
    I finally put gas in the tank of this little CBR to check out the new fuel system and get her fired up, just to find gas leaking all over my garage floor!!
    Had to take it all apart again to pull the tank, it was coming out of the fuel petcock. Most of you guys would prolly do this but for those of you like me reading this, when you FIRST put gas in a "new" just finished project just try a little to check it and see what happens. DO NOT put like two gallons in thinking its all good!!! I had myself a nice little "situation" there for a minute (more like 10) anyway, you get the picture, I'll let your imagination run with that...
    So what I discovered was that the petcock it self was not seated down tight enough to seal thoroughly ? You SHOULD probably replace that seal when rebuilding a whole new fuel delivery system?? I did not, certainly WILL next time!!!
    So, got her all back together and put just a little gas in and all is good. Holds fuel, fires up and runs like a raped ape! She is ready for a full tank of no-ethanol 91 and a nice warm, clear day to go experience what a little greybike is all about.
  2. RogueRC24
    Ah man, I totally get you on the filling the tank. I did that twice with big red until I learned to stop doing that. lol
    Any more just replace everything and order everything the first time. Don't dick around trying to save money.
    Look forward to some finished picks!
  3. linkken
    linkken Member
    Fortine, MT
    FINALLY got her out!
    Absolutely runs perfect, such a fun little bike!!
    Not like anything else I have, just light, nimble and super agile!!! IMG_1520.jpg that is the worst side... IMG_1522.jpg this is her good side.
  4. bmart
    bmart Member
    Charlotte, NC
    Mag-frackin-nificent.
  5. RogueRC24
    Hell yeah!! These little bikes are such a hoot!!
    Hell YES!!
    Very cool.
  7. linkken
    linkken Member
    Fortine, MT
    SOOOOOOOOOOOOOOOOOOOOO much %@&$in' FUN !
    Stay tuned more photos to come...
    RogueRC24 likes this.
  8. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    Quite a transformation.....well done, Link Ken!
  9. linkken
    linkken Member
    Fortine, MT
    Thank you!
    All you guys, you are awesome and I couldn't have done it this well without you!!
    I am absolutely ecstatic and truly very happy!!!
    Thank you for ALL your help.
    Bazza likes this.
  10. linkken
    linkken Member
    Fortine, MT
    wha whaaa, fuel delivery issue?
    The little bike is cutting out on me then dying! It is definitely intermittent as it will start back up and run fine for a while then it happens again?
    I switched the fuel to reserve and worked for a while then put it back to on runs for a while then cuts out?? I was thinking clogged filter but it is fine???
    I then suspected fuel pump but it does work although it was getting hot to the touch! Maybe the pump overheats stops working and then comes back on later, I don't know , what do you guys think??
    Some kind of vacuum problem???
  11. RogueRC24
    I once had a bad RegRec cause havoc with my coils while running. As soon as I applied throttle the bike would stall (outta fuel feeling). It would restart and idle, so I thought I was good and then give it gas and out it goes. Could be a bad RR, but it is a long shot.
  12. linkken
    linkken Member
    Fortine, MT
    yeah, thanks Rogue!
    My first thought was R/R, I got it home and tested at the battery and it is charging 14+ volts?
  13. RogueRC24
    That seems good. hmm.
  14. linkken
    linkken Member
    Fortine, MT
    Rode the piss out of her today to try and check the fuel cap and see if its a vacuum / breather problem, BUT, ran absolutely incredible ?
    When I checked the fuel pump, I just pushed the electrical connector firmly together and heard the pump run?
    I am thinking that it may have had poor connection because the bike runs incredibly fine now! In fact, I just put fresh tires on, new sprockets (14 T) up front and new chain!! Man this thing is fun!!!
    bmart and Captain 80s like this.
  15. RogueRC24
    Yeww!! One of the few bikes I would like to try. :)
    Bazza likes this.
  16. linkken
    linkken Member
    Fortine, MT
    precision instrument !
    like a scalpel!!
    sharp & crisp!!!
    sixdog, RogueRC24 and Bazza like this.
  17. linkken
    linkken Member
    Fortine, MT
  18. linkken
    linkken Member
    Fortine, MT
    Just a bump here, I will have some new stuff in the Spring.
    She had a good summer though. Didn't get to ride her as much as I would've liked to?
    Comfortably put away in the garage (better than the mess above) Hibernating staying warm till April or so.
  19. linkken
    linkken Member
    Fortine, MT
    Actually, there is a new little tidbit...
    She did get a new Tour Max fuel pump!
    Works perfect!!
    The cheap China crap was just to get her running on a budget, now we are perfecting!!!
    Bazza likes this.
  20. linkken
    linkken Member
    Fortine, MT
    Well, after successfully resurrecting the Wing, VFR and Vmax for the summer, this little girl doesn't want to get out of bed!
    She fired up just fine, however after a minute or so I started to see a "vapor" rise from her and a fuelish smell.
    Shut it down and upon inspection lots of fuel spilling out from the carburetor supply area.
    My WORST nightmare, the dreaded "T" at the carbys is leaking badly from the right hand side!!
    We are back to square one , gonna have to tear her all down AGAIN, pull the carbs off and pray!!!
