BabyBlade
Discussion in '1st & 2nd Generation 1983-1989' started by linkken, Nov 1, 2024.
  1. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    Replacing the o-rings ,while a bit of work, will obviously be a good investment for the future.
    I suspect I will be doing the same for some of mine that haven't been run in a while.
    Good luck! ;)
    You got this.
    But it is more research, procurement and preparing a good work area than praying.
  3. RogueRC24
    At least it is an inline 4. I perceive those to be easier to re-locate when completed than a V4. It will be all good. CMSNL or Web!ke for orings and things. There will be tariffs but you will get exactly what you want. You could also cross reference part numbers and see what is available in the US. Either way you got this!
  4. linkken
    linkken Member
    Fortine, MT
    Thanks guys!
    it just bums me out, I JUST did it all last year!!
    it only sat for the winter, what the heck?
    I did manage to find the "unobtainium" part!!!
    I really think that it is just that one o-ring , but since I found the tee with a bunch of o-rings (shipping from UK AND tariff ) I just got it for a spare anyway.
    I'll post photos...
    I'm just talking some time to let it all soak in
    If it is leaking from an o-ring that was replaced last year, it seems likely it was made from rubber not suitable to the task.
    Damage from install is possible, but I feel like it would have reared its ugly head before now.
    bmart likes this.
  6. RogueRC24
    ^^^ Agreed.
    I always use o-ring lube on a rebuild, no matter the application as well. Same with coolant hoses and insulators. Never caused a problem and always helps on installation. It is easy to cut the o-rings on a dry install in my mind.
  7. linkken
    linkken Member
    Fortine, MT
    They were supposed to be made of "Viton" , so I'm thinking install ! I WILL use some lubricant this time.
    Thank you, Thank you!!
    Love you guys!!!
  8. linkken
    linkken Member
    Fortine, MT
    I always did smell a little fuel.
    Just got worse sitting?
    Ok. Possible folded/rolled/knicked/torn oring.
  10. linkken
    linkken Member
    Fortine, MT
  11. linkken
    linkken Member
    Fortine, MT
    RogueRC24 likes this.
    Folded/torn?
  13. linkken
    linkken Member
    Fortine, MT
    looks like it was just pinched weird ?
    warmed it up and manipulated in my hand, put some lube on it and put it back in.
    no leak!
    bmart and Bazza like this.
  14. Bazza
    Bazza Member
    Awesome! :)
  15. linkken
    linkken Member
    Fortine, MT
    I got the unattainable parts coming, so I will just have a spare!
  16. RogueRC24
    I would not re-use that if it were me. It may seal, but if you lose any of that rubber/viton into the carbs, not only will you lose seal (potentially), but that little piece could get into float seals, screens and cause lack of flow.
    I am not a doomsday guy buy any means but I did spend 11 yrs in the oil industry fighting O-rings on the daily vs insane downhole applications.
    my 2c
    linkken, Bazza and bmart like this.
  17. linkken
    linkken Member
    Fortine, MT
    Yes, thank you Rogue!
    I'm still troubleshooting, at least the Tee itself seems fine. That is what concerns me he most, it is discontinued and EXTREMELY hard to get your hands on one!! I will now have a spare and it is coming with a bunch of new O-rings as well !!!
    Happy and Blessed...
    Very good advice and a very good decision to follow it. You're in there and you found the problem. Fix it right.
  19. rc24dk
    rc24dk New Member
    Denmark, DK
    Viton is fine for MC fuel. I think the white ones are often FDA approved. Which you dont need for fuel lines. I think NBR would also work. If it has a number it is hardness. 50 is relative soft 90 is relative hard. 70-75 is most common.
  20. linkken
    linkken Member
    Fortine, MT
    Yeah, thank you guys!
    I think they are kinda gray, food grade huh? LOL!!
    REALLY don't want to have to do this AGAIN!!!
