Backfire
Discussion in 'Mechanics Garage' started by SimonBurrows, Feb 5, 2019.
  1. SimonBurrows
    SimonBurrows New Member
    Hi
    It nearly starts, then a very loud backfire. Does this indicate a timing problem?
    Many thanks
    Simon
    unlikely on a VFR unless cams were removed recently for valve clearance adjustment.
  3. Thumbs
    Thumbs Member
    Bath(ish)
    Fuel starvation unless you’ve pulled the engine down
  4. squirrelman
    your starting fuel enrichment device (choke) system could be clogged. drain the float bowls and try again. and how long since your last ride ??
  5. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    You don’t mention model, history or anything.
    We can only guess without more information.
  6. SimonBurrows
    Thank you for the replies
    5th generation 1998. Things are getting worse, I have no fuel pump sound now when I switch the ignition on. I’ve checked the fuses around the battery area and all ok. Is there any other fuses anywhere?
  7. SimonBurrows
    It has been stood for almost a year
  8. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    With no fuel pump noise, that is the first place I would start. Doesn't matter what else works, but
    if the fuel pump no worky, then bike no runny. Get out the ol' multi-meter and check voltage at the
    pump.
  9. squirrelman
    you'll need to drain and flush petrol tank then fill with fresh fuel.
