Bad gas is part of the reason my vfr runs shitty.
Discussion in 'Mechanics Garage' started by sunofwolf, Jul 13, 2015.
  1. sunofwolf
    sunofwolf New Member
    not nice to me
  2. RotaryRocketeer
    RotaryRocketeer New Member
    OKC Metro, OK
    Seems to me that you should probably get the actual riding part down-pat first. Then worry about all this complex fuel wizardry/nonsense that you're always on about. The fine folks at Honda ENGINEERED (like, with math, science, and various other things you don't understand) the engine to run on 87. So put 87 in it, from a station that doesn't peddle E10, and just ride the fucking bike.
  3. duccmann
    And you expected something different. ... . Not
  4. 74ullc
    74ullc New Member
    Gulf Coast, Texas
    lucky...send some my way please.
  5. NormK
    NormK New Member
    Personally I think it might be better if you try drinking a bit of 87 or even 89 would do, might even be worth mixing the 2 together,and then stick one of these great Denso spark plug in your mouth to see if it still sparks
  6. sunofwolf
    ok you first then let me know
  7. sportcruiser
    sportcruiser New Member
    Lake Worth, FL
    I don't get all of the ethanol talk. I just fill my bike, car, boat and generators and run them. If you are going to park then for a while, simply add some Stabil.
  8. sunofwolf
    vfr running better but the idle is way too low, so far I can't adj with the knob. the only thing wrong right now is either the cable or the wax unit. it will stall to easy at take off 1,000 rpm or less-needs to be 1400-1500 on the tach. I can use the throttle to increase the rpm's but is tricky :boink:
  9. Arnzinator
    Arnzinator New Member
    Central Massachusetts
    Just twist the throttle to increase RPM's, pretty simple.:crazy:
  10. 34468 Randy
    Now. There's an understatement!
  11. duccmann
    Can you say NIMROD
  12. sunofwolf
    most of the problems were solved today, put 1 gal of 87-now its a full tank of gas-something I do not like on back roads, but it pick up idle a little and ran much better riding had a few bugs like the gas. the more I ride the vfr-the better it seems to get- very odd machine. I fix ever thing myself.
  13. thx1138
    thx1138 New Member
    Perth
    That was a really stupid post norm.
    I can't imagine why you would give advice like that.
    Why on earth would you recommend he puts the spark plug in the wrong end?
  14. duccmann
    Funny stuff...the (butt) of jokes he is....
  15. RobVG
    RobVG Member
    White Rock BC
    "All the world is grooving on Banapple gas"
  16. Badbilly
    No need to figure it oot. Just listen for the voices..
  17. thx1138
    thx1138 New Member
    Perth
    I hear voices, they tell me to buy more parts and more motorcycles.
    I usually listen.
  18. NormK
    NormK New Member
    So silly of me how could I make such a mistake
  19. sunofwolf
    ya a bad ass
  20. Alaskan
    Alaskan Member
    Alaska
    Odds are there is a station that sells ethanol-free gas somewhere near you. Check out the PURE GAS app on the iTunes store.
    Beyond that, you are overthinking all this. Just go ride.
