bad gasket and broken bolt on exhaust intake for cylinder#1
Discussion in 'Mechanics Garage' started by akabdog, Jun 30, 2010.
  1. donald branscom
    donald branscom New Member
    Guerneville CA
    I agree that a standard tap handle would be nice.
    Many hardware stores do not carry them anymore.
  2. tinkerinWstuff
    Mark my words.....
    The chances of success are slim taking the lazy way. The chances of creating larger problems by breaking off a drill bit thru poor access to the hole or drilling off center etc.... are high. The risks outweigh the gain in trying to take the "easy way"
  3. TOE CUTTER
    This is a one shot deal to get it right so take your time and make sure you go in straight and true the first time and you should be ok.
  4. donald branscom
    Guerneville CA
    IF the camera can take a photo then the access my be sufficient.
  5. akabdog
    akabdog New Member
    San Jose, CA
    the conclusion
    Thanks to everyone for the advice on this. I replaced all the bolts except for the one that broke off inside of there. For that one I used some metal wire and a zip tie. It's not the optimum solution but it's held great for about 5k miles so far. Here is a picture in case anyone else gets in this pickle. Of course, the moral of the store is do not over tighten these bolts...
    Thanks again to all!
