ball vs. tapered head bearings?
Discussion in '3rd & 4th Generation 1990-1997' started by turboguzzi, Dec 12, 2011.
  1. TOE CUTTER
    I am one that would not use them for wheel bearing but for a head set I can not possibly see and issue.
  2. Knife
    Knife Member
    Downingtown, PA 19335
    I'm perfectly content with my sensitive balls. I'm going to keep them.
  3. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    And trade off all of the load bearing capabilities and durability? :biggrin:
    But then again, there is something to be said for a higher speed rating...
  4. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    The First Gen came with tappered bearings I've replaced mine three times now. They are factory size only. No other manufactures make them, only the one for Honda. I have found them to work best torqued to 15# vs the books 10-12#. The bike feels like it's on rails. There was some stuff I read that the bottom bearing would move around like .001. That's why they went to ball type. Probably cheaper though.
  5. Hammerspur
    Hammerspur New Member
    Cranston, RI
  6. Zland76
    Zland76 New Member
    Just ordered all balls off ebay
    31.00 Shipped
  7. reg71
    Sikeston, MO
    I replaced mine (with help) with the tapered ones from allballs a couple years ago and they seem fine to me. Probably have put 20000 miles or so on them and never noticed a prob.
  8. Renuka
    Renuka New Member
    Mumbai
    We can replace ball bearings with some bearings only but this is possible in some places so buying ball bearings is the beat one.
  9. REEK
    REEK New Member
    Sacramento CA
    GSXRs went to balls as an effort to eek out every ounce of unnecessary weight when they got porky in the late 80's and early 90's. I think they went back to rollers for durability issues later in the GSXR models. Not sure where they landed after the loss of the double cradle frames.
    I've been using all balls tapered steerer bearings for years on various applications with no problems. I too wouldn't use them on my wheels though.
  10. Badbilly
    Do I recall that the 90-93 VFRs had cheesy races? plastic (??) Fuzzy on this too but I think the better bearing can be found on an ST1100.
  11. ridervfr
    :thumbsup: far oot :hippie: I like oem on my Honda, I did the tapered after market route though on my Kawasaki. Seems Kawi in their infinate cheap wisdom chose to use loose balls on their steering head on their Ninja 500. I know its an inexpenisve bike, but would expect at least captured balls? I have a 40 year old British bicycle that has loose balls (un-captured) too, but would expect a little more for a motorcycle.
    I did the All-Balls on the Kawi and it is a nice set-up. I am happy as if I went with OEM on that application, I would still have an archaic backward steering bearing set-up. Best mod was going to a bonafied radial tyre compared to the bias ply tyres that were on there.
  12. ridervfr
  13. richierex
    richierex New Member
    you do not understand what a steering damper does, it reacts to sudden inputs, not slow turns as in normal riding, in fact it would be more useful on a bike with ball bearings and less static friction. my opinion only, dont start cos i dont care.
  14. tinkerinWstuff
    I do realize that and have had one on the wish list for my DR650 to help offroad.
    but the point I was trying to make was if someone can feel such a subtle difference between a ball and a tapered bearing, then wouldn't ANYTHING on the steering also affect that sensitive feel? Are we talking about a straw man?
  15. richierex
    no we are talking about a steering damper that damps sharp inputs, like I said, I am not prepared to argue to the finest end of a fart about this, and no, most people cant feel any difference, this is the internet where everybody knows everything:numbness:
  16. tinkerinWstuff
    so when it's not damping sharp inputs, then it's so smooth and resistance free that the feel to a racer is imperceptible? even more imperceptible than the difference between tapered rollers and ball bearings?
    as was my question posed to post #13 which you responded to
    http://vfrworld.com/forums/showthre...-head-bearings?p=340738&viewfull=1#post340738
    Who's arguing to a fart? I'm asking questions. Defensive much?
  17. richierex
    i dont need to defend myself, a good damper is imperceptable at low speeds, try one, not many on here can tell the difference whether taper rollers are fitted or ball bearings, its all internet posturing, and I dont take part in that kind of thing. I always think you should only say on the internet what you would say in person. Like I said, its arguement for arguements sake and you may be turning into the biggest culprit. goodnight
  18. squirrelman
    I just saw the steering stem from an '06 Yam R6: Balls !!
  19. ridervfr
    ^yep, Hi Ice-Hunchin :wave: are you flooded oot?
