battery problems
Discussion in 'Mechanics Garage' started by kurupt, Jan 25, 2010.
  1. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    BBwong:
    betarce nailed it again.
    Yes, if your battery is on the 'low' side it can die in traffic as in your situation.
    Get a new battery and a battery tender and you are good to go.
    BZ
  2. bbwong
    bbwong New Member
    New Jersey
    Thanks all for the replies. The battery is on a tender during the winter. I've only had the bike for about 3 years and don't know when it was replaced prior and am unsure how well it was taken care of by the PO. I figure the cost of a new battery and a quick check of the charging system is worth the piece of mind.
    How does one bump/push start a bike? I've done it with cars, so I'm guessing the process is the same. In gear, clutch pulled in, run, jump on, and pop the clutch? How fast do you need to be rolling? I don't think I'm coordinated for all that.
  3. betarace
    betarace New Member
    Middleburg, VA
    2nd gear, key in on position, standing on pegs, clutch in
    roll down hill or have your wife push you
    simulaneously drop your a$$ onto the seat and release clutch
    ride away
  4. RGonVFR
    RGonVFR New Member
    SF Bay Area
    Absolutely in second gear. I had the same thing happen today. My battery was dead a few months ago, had it charged at a local bike shop, then it sat until today. My bad for not having a tender.
    Is there a specific type of tender you guys would recommend? I read the $35 dollar above, but haven't seen one for sale that inexpensively. Please advise.
  5. betarace
    betarace New Member
    Middleburg, VA
  6. tinkerinWstuff
  7. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    Whatever battery charger you buy for a motorcycle make sure it outputs no more than 1.5 amps or else fry your battery will.
  8. Junyr
    Junyr New Member
    Des Moines, Iowa, United States
    Also on the tender if it has an 'monitor' feature that'd be great. Charge up to full then auto shutoff, while it's shut off it monitors and when the voltage gets too low it turns back on. Plug it in at the beginning fo winter and forget about it.
  9. Dukiedook
    Kansas City, USA
    If you stick it on all winter and don't check it or reset it make sure you get one that compensates for temperature and that re-cycles after a certain amount of days of charge.
  10. RGonVFR
    RGonVFR New Member
    SF Bay Area
    Thank you for the suggestions and information. My new battery tender is on the way to my ailing battery.
  11. The_Pork_Snorkle
    The_Pork_Snorkle Banned
    you shouls also check the ground wires for poor connections
