belt drive
Discussion in 'Mechanics Garage' started by cirv, Aug 12, 2007.
  1. nozzle
    nozzle New Member
    Southern Maryland
    Was it crunchy or smoothy? :biggrin:
  2. eddievalleytrailer
    eddievalleytrailer Member
    Jonesborough, TN
    I guess I'd call it crunchy. That Buell POS would shake your teeth out, but it pulls like crazy. If you wanted a wheelie machine, the Buell is a great choice, and the basakward brakes are so touchy it's hard NOT to do a stoppie. The seating position SUCKS. It leans the rider so far forward you have to look WAY up just to see the road.
    Nozzle, You wouldn't edit a quote, would you?:biggrin:
  3. Gatekeeper
    Gatekeeper New Member
    I'd rather listen to chain noise than belt whine. I can fix a chain with imagination and limp home.
    And for KC, the new Buell has a Rotax lump.
  4. dlman
    dlman New Member
    Denver
    I put chain lube that I got from wally world on my chain. I thought it was going to be like oil but it was more like grease. And I haven't had to put any on in over a thousand miles.
    I would own a buell. It sounds like a lot of fun. They look great too. But if I am going to have a collectors spirit I should have tons of money first.
  5. Spike
    Spike New Member
    Before we bought our house, my wife and I had a condo. One of our neighbors was the head of a large local Harley/Buell dealer. He had a Buell -- loud as heck when he would leave in the morning! But he also owned a -- wait for it -- Honda! ST1300 to be exact. & why did he buy it? the reliability. No, I am not joking. For regular commuting to work, he usually took the Honda, because of the reliability issues, he didn't want to rack up the miles on the Buell and have to fix it. He saved the buell for weekend cruises, and shop events. The Honda was for regular riding, and any time he rode with his son.
  6. dlman
    dlman New Member
    Denver
    I think that we need more American bike makers. Not the chopper/cruisers but good ol fashion American muscle sportbike. I wouldn't mind a 2.5 lter V8 sport bike.
  7. Spike
    Spike New Member
    You got Fischer now, and Motocyz supposedly coming up...
    real tough to compete with the Japanese on the sport bikes though, just ask Triumph.
  8. tbones86
    tbones86 New Member
    N/W Central Wisconsin
    Call me crazy.....
    Call me crazy but after doing a little research on the new Buell 1125R & It appears to be a pretty sweet ride. Here are the spec's & a link if it works
    MSRP $11,995
    Dimensions U.S. Units
    Overall Length 78.6 in.
    Overall Width 28.2 in.
    Seat Height:
    Standard 30.5 in.
    Wheelbase 54.6 in.
    Tires:
    Type Pirelli®
    Front Diablo Corsa III (model)
    120/70 ZR-17 (specifications)
    Rear Diablo Corsa III (model)
    180/55 ZR-17 (specifications)
    Fuel Capacity 5.6 gal.
    Reserve Fuel Capacity 0.8 gal.
    Weight:
    Dry Weight 375 lbs.
    Gross Rating 850 lbs.
    Load Capacity 395 lbs.
    Engine U.S. Units
    Engine Liquid-cooled 1125cc Helicon® V-Twin
    Valve Train DOHC, 4 valves per cylinder, finger follower design & shimming
    Bore x Stroke:
    Bore 4.055 in.
    Stroke 2.658 in.
    Displacement 68.7 cu. in.
    Compression Ratio 12.3:1
    Fuel Delivery Dual 61 mm down draft throttle bodies, DDFI III fuel injection
    Exhaust Tuned, tri-pass resonance chamber with integral helmholtz tuning and mass-centralized mounting
    Torque 82 ft. lbs. @ 8000 RPM
    Horsepower 146 HP @ 9800 RPM
    Primary Drive Helical Gear, 0.554:1 (36/65) ratio
    Final Drive Constant path, 14 mm pitch aramid-reinforced Goodyear® Hibrex® belt with Flexten® Plus technology, 2.593:1 (70/27) ratio
    Clutch Wet, multi-plate, Hydraulic Vacuum Assist (HVA) Slipper Action Clutch, hydraulic clutch lever effort
    Transmission 6-speed, straight cut gears
    Chassis U.S. Units
    Frame Aluminum frame, fuel in frame
    Front Fork 47 mm Showa® inverted forks with adjustable compression damping, rebound damping and spring preload
    Rear Shock Showa® coil over monoshock with adjustable compression damping, rebound damping and spring preload
    Wheels:
    Color Diamond Blue
    Front 6-spoke, ZTL™ cast aluminum (type)
    3.5 in. (diameter)
    17 in. (width)
    Rear 6-spoke, cast aluminum (type)
    5.5 in. (diameter)
    17 in. (width)
    Brakes:
    Front ZTL™-type brake, 8-piston, fixed caliper, 375 mm single sided, inside out, stainless steel, floating rotor
    Rear Two-piston, direct mount caliper, 240 mm stainless steel, fixed rotor
    Photos and full specs: Buell Motorcycles 1125r website http://www.buell.com/en_us/bikes/sportbike/1125r/index.asp
  9. mello dude
    Iran, Islamic Republic of
    Buell is using the old mill with upped cubes Aprillia used to buy for their sport bikes. (Aprillia is now making there own in how instead of buying from Rotax.) So the bike will finally be the real deal - ~ 120hp and 75ft lbs torque at the rear wheel.
    -- Not that I want one.
    MD
  10. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    WARNING!
    Radar has just picked up a cruise missle en route to tbones in Wisconsin.
    The missle appears to have come from a rebel group located in the People's Communist Republic of New Jersey. The groups leader, who goes by the surname "KC 10 FE" released the following statement: "Anybody who praises Harley Davidson products will face the wrath of God as we rain fire upon them! Such praise will meet swift judgment...and crunchy peanut butter!"
  11. tbones86
    tbones86 New Member
    Not exactly so per this exurpt from an interveiw w/ Erik Buell.
    Kneeslider: Were you planning to use a Rotax engine from the beginning or was it one of several choices that you were considering? Has the Revolution engine ever been considered as an option for this or any new model?
    Erik Buell: Well this is really a Buell engine not a Rotax, it was built for us by Rotax but this is completely our own engine built to our specification, it’s a clean design, not something that existed at all. Other than maybe the oil filter or something like that, this is totally new, it’s not used anywhere else.
    The second time we had taken a run at a water cooled superbike it was actually going to be using the Revolution engine, it was in the mid ‘90s we started that project, which wound up being the V-Rod engine and what happened that time was the specifications we needed and the specifications Harley needed just couldn’t gel well enough and the Harley one took precedence but the specifications of what we needed were just too different.
  12. tbones86
    tbones86 New Member
    Being a WI native I know several people who are gainfully employed because HD & Buell. Not neccesarliy praising HD/Buell but when props are due they are given & crunchy peanut butter:biggrin:
  13. nozzle
    nozzle New Member
    Southern Maryland
    Can we agree to call it a cut-n-paste disagreement or something that sounds nicer? :biggrin:
    I don't want to end up lumped in with NBA Ref's and such. :wink:
  14. mello dude
    Bones - thanks- --I think I read the Aprillia thing in Cycle World.
    MD
    Crunchy PBJ's to all!
  15. eddievalleytrailer
    Jonesborough, TN
    How about "Quote Enhancement":smokin:
  16. veefer800canuck
    veefer800canuck New Member
    Crazy Larry converted his 500 Interceptor to belt drive:
    And he's currently converting his RC45 to belt drive as well, here's the prototype parts:
    That's a Gates Polychain belt and a Buell rear sprocket machined/modified with an RC45 inner driven hub. And yes, it only has 2 bolts holding it on. (for now)
  17. mello dude
    Sick puppy ---- DISGUSTING ! Especially the RC45 !
    MD
    Hey Canuck - why dont you hang out on this side of the fence awhile?
  18. PorscheBob
    PorscheBob New Member
    Los Altos, California USA
    KYB jelly? Hmmmm, sounds good. I knew we rode sexy bikes. :tongue:
  19. veefer800canuck
    I'm here now, aren't I??? :)
  20. KC-10 FE
    KC-10 FE New Member
    I wonder how this slipped by without me noticing? This is funny, I don't care who you are.
    I can neither confirm nor deny the origin of said projectile.
    KC-10 FE out...
    :plane:
