Bent handlebar solutions?
Discussion in 'Mechanics Garage' started by courtvfr, Feb 24, 2020.
  1. courtvfr
    courtvfr New Member
    https://drive.google.com/open?id=1bFvUH_Ua24fDtecRsRtXfYP2nDDXzXUf
    Hope the video links. Basically at full lock, one side has about 5 mm gap between the horn switch and the fuel tank, and the right side has approx 10 mm gap between the starter switch and the tank. I'm assuming the left bar is bent (I bent the right already but got a salvaged replacement).
    Now I've been riding with these bars like this for a long time, however it is bugging me. Could I file off the tabs at the base of the clip on, so that I can rotate the fork up to give the switch clearance and therefore 'straightening' the bars. Would this cause any other problems?
    I was thinking of getting another bar from ebay but I'd say the majority of salvage parts there are from crashed bikes, so the bars could end up being just as bent..
    The tyre also has wear on one side but I think this is due to age and the road camber rather than any structural damage.
    https://drive.google.com/open?id=1bBFHSyUOixArBSFOgqgzbMyKHDy8RwK-
  2. Norse
    Norse New Member
    Denmark
    Have you actually taken the bars off and checked if they are bent?
    You are aware that the left and right side switch housings are not identical, right? And that they may not be aligned exactly the same on the bars.
    Never start fixing a problem until you know that there actually is a problem to fix.
    Thumbs likes this.
  3. Darth Vader
    Darth Vader New Member
    melton mowbray
    Try this first, your forks might be out of whack
