Best Chain Lube
Discussion in '5th Generation 1998-2001' started by warchild, Jul 22, 2006.
  1. rangemaster
    rangemaster New Member
    Albuquerque, New Mexico
    I think DuPont, for whatever reason, changed the formulation of the 'chain lube'. Now it's some runny worthless s--t. The can looks identical EXCEPT it doesn't say wax on it anymore. The search begins for a suitable replacement, because I just used the last of what I had of the good stuff. Any suggestions welcome.
    #81
  2. white_335i
    white_335i New Member
    Houston
    Belray. No slinging.
    #82
  3. 34468 Randy
    Is that the Dupont Chain Saver....in the yellow can? I hope not cause it is great stuff. I have two cans of it on my bench and if they don't make the stuff any more, be damned if I am offering it to anyone else.....cept those at R3 of course.
    #83
  4. Glenngt750
    Glenngt750 New Member
    Edmonton, Alberta, Canada
    Nobody has mentioned to Always put lube on a warm chain, as in when you have gone for a ride, already. Also, lube the inner run of the chain. It is harder to do, but centrifical force will cause the lube to travel to the outside of the chain. If you just put it on the outer run, it would not lube much of anything, except your wheel! BEL-RAY is the best! It hardly flings off, and seems to last a good long time.
    #84
  5. slowbird
    slowbird Member
    Toronto, Ontario.
    Yea, the Dupont Multi-Purpose lube has changed their formula.
    DuPont Teflon Chain Saver - DuPont Teflon Chain Lube - webBikeWorld
    Dupont now recommends Motorcyclists use their "chain saver" as their new Multi-Purpose lube isn't suitable for chains.
    ....and I am all for The Dupont Chain Lube and Tirox cleaner :cool:
    #85
  6. 34468 Randy
    Now. If we could just get that Chain Saver here in Canada. Not available here, at least not on the west coast. I have to go down to Burlington Wa to get mine.
    #86
  7. slowbird
    slowbird Member
    Toronto, Ontario.
    Randy, I've found Chain-Saver at any Lowes hardware stores.
    #87
  8. Badbilly
    Is this outfit in Burlington the same place you buy your jackets?
    #88
  9. silverbullet132
    silverbullet132 New Member
    I never bother to clean my chain, just lube every tank or two with Wurth HHS2000.
    #89
  10. 34468 Randy
    We only have one Lowes out bere and it is about 50 miles away. ut thanks. When I run out that will be a nice road trip.
    And BB. I bought that wonderful garment north of 49.
    #90
  11. Badbilly
    Ya had me goin there for a minute. I thought by "49" that Texas had dropped out of The Union or Washington or Colorado had just forgotten about the whole thing..
    #91
  12. proverbio
    proverbio New Member
    San Gabriel Valley, CA
    Ditto... I thought I was the only left using gear oil.
    #92
  13. Badbilly
    Gear oil is also great for belt drives and Harleys.
    #93
  14. Badbilly
    #94
  15. chrisallison
    chrisallison New Member
    preston England
    gear oil works great for me. 28000 miles on did chain & still going strong.
    #95
