Better lighting needed
Discussion in '6th Generation 2002-2013' started by rich stone, Nov 22, 2018.
  1. Diving Pete
    That's fairly easy to answer - sorry if it feels we had to drag it out - lol
    RIDE recommended for 2019 are:
    Phillips extreme vision +130 - cheapest
    Osram xracer
    Osram nightracer 110
    You may also want to check out post 11 as I get the feeling that the US doesnt allow all the lights to work... & in conjunction with a bulb upgrade this may perform miracles..
    Allyance likes this.
  2. Mike Cronis
    Mike Cronis New Member
    I find the LED motorcycle headlights lacking. I have a Ninja 400 ABS and also tried the Honda CBR 500R and .. not good.
    I recommend changing the bulbs with PIAA Hyper Whites. I'm having it done to mine before pickup. I've also done that with my old Superhawk. Really helps. That and.. of course.. check the darn alignment! The Superhawk has two gold cogs that you can raise for up/down action inside the dash-area behind the bulbs. Not sure if the Interceptor is the same (I don't even have my first one yet!) Expecting.. pregnant..... with anticipation!
    34468 Randy likes this.
  3. Samuel
    Samuel Member
    Los Angeles County
  4. rich stone
    rich stone New Member
    Leds are not lacking on old bikes if done properly. As has been mentioned, the relector has a lot to do with it. I have Trucklite brand sealed unites on two nortons and they are fantastic. A friend is running a led bulb in an oem brit relectpr with good result. But i have tried the same bulb in different reflector with poor results.
    My bike is going up on the table tomorrow for a long list of work including horns that can be heard and denali leds. And possibly piaa bulbs.
    Not all mc headlites are lacking, my vstrom is better than many cars.
  5. Leon67
    Leon67 New Member
    Greece
    Try higher spec H7 but not higher wattage. Philips or OSRAM made for motorcycles are a good bet.
  6. squirrelman
    Proper adjustment is a must, and most states have clear standards.
  7. rich stone
    thank you squirrel for stating the obvious.
    s
