Bike won't stay running
Discussion in '1st & 2nd Generation 1983-1989' started by Bwillis210, Jun 16, 2023.
    I use a strip of medium stock paper (~7mm wide) as a feeler gage. Get a nice repeatable drag on the base carb (over the small hole in the bore) using the idle adjust and match that drag on the remaining carbs, "snapping" the throttle every now and then and rechecking. If that doesn't get you an adjustable idle down below 1000 rpm, you have missed something else in your carb "rebuild".
    #41
  2. Bwillis210
    Bwillis210 New Member
    Still nothing I did that and now it won't stay going without the choke on I've retraced my steps through the whole thing and still can't find where I would have messed up at, I watched and followed perfectly on a video I found from Matt tries to do things and still doesn't want to go, what do you think I'm missing
    #42
  3. squirrelman
    mixture screws set at about two turns out ? dija clean idle jets properly ?
    did you reset float levels ?
    #43
  4. Bwillis210
    Okay so the mixture scre when ever I bring that out 2 turns it just pours gas everywhere and also cleaned out the idle jets properly as well, I let them soak
    #44
  5. squirrelman
    somethings way, way wrong. do you actually know where the idle mixture screws are located ? not the float bowl drain screws.........
    soaking is not always sufficient to clean an idle jet, and thats why a wire [ten-thousandths diameter] must be used.
    #45
  6. Bwillis210
    I'm dumb as he'll lol I don't know why I wad mixing those up so bad give me one sec in those
    #46
  7. squirrelman
    read, study, follow carb cleaning steps in honda service manual, and find a youtube or two.
    asking questions is encouraged here
    #47
  8. Bwillis210
    Okay where is the fuel mixture screws I cannot find it I swear I knew where it was but I guess not
    #48
  9. squirrelman
    :mad: read the damn manual, kid
    #49
  10. Bwillis210
    I don't have a damn manual
    #50
  11. squirrelman
    as a young, inexperienced bike owner, the honda service manual is an absolute necessity. it will save you time, increase your understanding and keep you from screwin things up too bad [if you read it].
    manual can be downloaded free on this site i believe ;)
    #51
  12. straycat
    Hey there, this is one of the best v4 carb cleaning channels on youtube (IMHO).
    https://www.youtube.com/@thecarbspa/videos
    here is the first video of 14 on how to properly service your v4 carbs
    these will take you step by step in a very clear and concise manner
    #52
  13. Bwillis210
    It's hard to see but that is where everyone says the mixture screw is supposed to be there is nothing there and the other side is blocked off
    #53
  14. squirrelman
    you still dont have a clue, lad :rolleyes:
    #54
  15. Bwillis210
    Bro you said asking question is encouraged did you not? The other side is blocked off right and this side has no where for a damn screw, I'm asking where it is now. So would you mind telling me where it is please? Instead of some snarky ass reply thank you
    #55
  16. squirrelman
    its hard to describe, but clear photos in the service manual show the location
    #56
  17. Bwillis210
    All you had to do was just tell me to drill out the cap on the other side, it wouldn't have been that hard to say that I finally found a damn manual you could've just been a nice person and just told me and save me and hour thanks
    #57
  18. squirrelman
    im hanging my hung-over head in shame :(
    #58
  19. Bwillis210
    Suck my dick hope you end up dying alone
    #59
  20. squirrelman
    thats well out of order, kid, even if i could find it :confused:
    #60
