Bought Wrecked '86 VFR, Where Do I Go From Here??
Discussion in 'General VFR Discussions' started by mcpmartin, Nov 9, 2021.
  1. Terry Smith
    Your brake lights are powered through fuse E, along the W/G wire to each switch, back through G/Y wire, passes through a single 3P plug (I presume in the tail somewhere) and then goes to the bulbs, and back along the G ground wire. If you get 12V at the W/G wire at say the front brake switch (to earth) then you can rule out power supply. If you jumper around the switch, you can eliminate the switch.
    #81
    mcpmartin likes this.
  2. mcpmartin
    mcpmartin New Member
    Dallas, TX
    Update: It's taken a long time to get here, and I appreciate everyone helping me figure things out. Aside from exhaust needing to be swappped out with my "new-to-me" (gently used) Kerker exhaust, I'm calling this bike finished. It starts, idles, and drives great! This bike is a ton of fun, and I cannot complain about anything. Thanks again to everyone who has assisted with answering my questions along the rebuild process. It's hard to believe I bought this bike from the City of Ft Worth (auction) for $300 from what I can only assume was a bad wreck. Fast forward about 10 months-ish, and it's back on the road in style.
    #82
    Colddevil, RllwJoe and Thumbs like this.
    Good job!! They look so good with matching 17" wheels.
    #83
  4. ceptorman
    ceptorman New Member
    WOW.....great job. The bike looks great....ride on.
    #84
  5. sixdog
    sixdog Insider
    Wow!
    #85
