Breaking in my Pr 4 m tires and extreme EBC pads-most powerfull stoppers!
Discussion in 'General VFR Discussions' started by sunofwolf, Apr 15, 2016.
  1. tyarosevich
    tyarosevich New Member
    Seattle, WA
    He needs less tire pressure to get back up the 30 miles of forest service road to his enclave.
  2. Lint
    Lint Member
    Simi Valley, Ca.
    And how have you come across this conclusion, exactly? Based on decades of manufacturing, testing, racing and spending millions of dollars on R&D, no doubt... I'm sure years of MotoGP experience has led you to this decision.
  3. sunofwolf
    sunofwolf New Member
    I go by how the tire works for me, not on what some race rider thinks
  4. duccmann
    38.5....just like his gas...1.5 at a time.
    Dont waste your breath Harold
  5. sunofwolf
    :nelson:
    and I just filled up my tank 1.5 gals too
  6. Lint
    Lint Member
    Simi Valley, Ca.
    SOW,
    I am going by what the heads of Michelin's technical department tells me, as well as 8000 miles of track, freeway, canyons, etc. Since I actually wore out my front tire a little sooner than my back due to trail braking into miles of canyon turns, I can attest to the fact that they know what they are talking about. I can tell you that leaned over and exiting a turn at nearly full throttle well into the VTEC peak HP, the factory recommended pressure holds grip very well. I'm not trying to brag that I am some uber GP rider, rather relate that I have pushed these tires to the ragged edge of their limit and that they held. As a matter of fact, I have broken the back tire free under acceleration during corner exits and it was controllable at all times. 80 miles of track day, in high temps, canyons run at all temps, even cold and wet and they held. You have nothing to lose by listening to advise from those that have gone before you. Just as I know you have nothing to gain by running some arbitrary pressure made up in your head with no empirical data with which to back up your decision. Ultimately it is your bike, your decision, but I have done my due diligence as well as having practical first hand experience. It just doesn't make sense to do something without having anything to back up your idea...
  7. V4toTour
    V4toTour New Member
  8. Lint
    Lint Member
    Simi Valley, Ca.
    Finally, we have a picture of him.
  9. redwing750
    redwing750 New Member
    Buffalo NY
    Yep, gotta watch that fuel tank pressure!
  10. sunofwolf
    Well I ride on bumpy roads and less air works better for me. I have a DMR rear shock coming-I hope that helps.:spider:
  11. Lint
    Lint Member
    Simi Valley, Ca.
    Have you considered that you have your suspension set too hard? I know nothing about you, so I don't know your weight, but it's something to consider. You're getting a DMR shock, but what about the forks? Your bike needs to stay balanced. A good aftermarket setup will go a long way towards taking the bite out of bumps.
