Cam lobe flattening '85 VF500
Discussion in '1st & 2nd Generation 1983-1989' started by tinkerinWstuff, Oct 9, 2009.
  1. tinkerinWstuff
    I interconnected mine, as I said in an earlier post, because it was the easiest way for the time being. Until the next time the carb assembly is removed, this is the easiest way. This was done AFTER there was already surging, not the cause of it. As a matter of fact, I believe the performance of my ride has improved.
    I disagree that the performance would be any different with them interconnected because the hocky pucky thingy does the SAME THING. Only the valve opens and allows the vacuum tube coming up from the canister to be open to the ECS ports.
    And why would balancing have ANYTHING to do with interconnecting the ECS lines? Balancing is adjusting the butterfly valves in the carbs and the ECS ports are between the butterfly and the slider. No affect on balance - engine vacuum is measured at the ports in the cylinder head between the intake valves and the carb butterflys.
    #81
    From Kevin Ash's website, a British journalist:
    Honda VFR1200F | Ash On Bikes
    The VFR750 reversed the dreadful reputation for unreliability of Honda’s first big V-fours, the VF700 and 750 cruisers and VF750F of 1982, the VF500 as well, all notorious for their rapid-wearing camshafts, sagging camchains, breaking camchain tensioners and other issues. The VFR750 was designed to put that right, and even did away with camchains altogether by using a costly gear train to drive the camshafts. It was dependable, durable, lasted forever, and gained a huge fanbase for its combination of quality and all-round ability: this was the bike that the term sports-tourer was coined for.
    #82
  3. loopsandlogic
    loopsandlogic New Member
    Sorry for jumping in, but I'm having the light surging during mid and high rpms.
    Just as you described actually....
    So I ask, what is a ECS port??
    I assembled my carbs according to the Honda shop manual, and I have them off again, ready for new seals.
    The old float bowl seals went south....so before I put new seals and assemble these PITA carbs, what should I look for in particular that would
    cause my problem??
    Fuel flow is good and at a good rate.
    Thank you for any help...and if you want, I could start another thread :)
    #83
  4. tinkerinWstuff
    someone's gonna kick my ass when I don't get this exactly right....
    I'll do my best...
    The ECS ports are the vacuum port on the side used to recycle collected fuel fumes from the carbon canister on the front of the bike. Technically I don't know that you'd really call it a vacumm port but it looks like one with vacuum lines going to it.
    In my case, the problem was the #90 main jets. If your main jets were clear and clean (along with no vacuum leaks) and you had surging issues you may consider trying a larger main jet. My surging issues were very noticable and HP would drop as rather than build as the RPM's were climbing. I went to a #102 and didn't try any others.
    If your surging is not very noticable, you may want to try a (assuming you have a #90 now) #92 or #95. If it's very irritating, try #97, 100, or 102.
    Look at your mains and see what number is stamped on the side.
    I got mine at a salvage yard for $4/ea if I remember right.
    Let me know if you have any other question - happy to help.
    #84
  5. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    I have no clue what an ECS port is either. Since the problem is at mid and high rpm's (assuming this is large throttle openings) then it would suggest maybe the main jets as was with Tink's. I'd also check the float height as this could also be the source of the problem too.
    #85
  6. tinkerinWstuff
    +1 JamieD
    I believe the photo below shows what I have referred to as the ECS port. In my troubleshooting, I removed the vacuum tubes and plugged these orifaces just to eliminate any possible sources of vacuum leak. When the system operates normally, fumes from the carbon canistor would be recycled back to the motor thru this tube. I have California carbs so I couldn't say for certain if 48states are the same way.
    notice the vacuum tube on the side of the carb. This photo was marked up with red arrows and used in a previous post to show the pry location to remove carbs.
    #86
  7. loopsandlogic
    Well, I don't have the ECS ports. Nor do I have the canister.
    But I will look at my jets again before buttoning them up. And I'll make sure to reset the float heights.
    My problem is more of an rpm not so much as an throttle position.
    If I crank it from 2k rpm it won't surge, but as soon as I get to 5500rpm and up, it starts to surge very little.
    Whether im cruising (maintaining throttle position at that rpm) or I'm goosing it from there.
    But yeah, I'll check the jets. Once together, and it still has it, I'll just open up the Vacuum diaphragms with the carbs on the bike to see if I have any torn.
    Some member on here sells the kit of New Diaphragms on Ebay...Right???
    Its nice you can get to the tops of the carbs on the bike....LOL
    #87
  8. tinkerinWstuff
    because of how the vacuum sliders work in these carbs, what you describe could still be considered throttle position.
    If you're at idle and crank the throttle butterfly wide open, the carb and main jet are still not "wide open". The slide will be in a lower position with the slide needle plugging the main jet.
    As the RPM's climb, vacuum increases in the motor, and the slide moves up, further exposing the main jet.
    When we refer to throttle position, we really mean "slide position" and around 5000ish rpm would normally be around mid throttle and definately into the main jet circuit of the carb.
    If you remember the old two strokes from the 70's and stuff, you'd be at idle and crank throttle and the motor would bog down because the carb would lose vacuum. They always seemed more responsive if you'd ease on the throttle verses dumping it WOT. The carbs with vacuum slides were the fix for this.
    My recommendation for you would be to increase your main jet size. If you're at 90, go to 95. If your at 95, try 100. There are sizes in between like 92 and 97 but too small of a change may not result in a noticable enough change to show if you're on the right track.
    #88
  9. loopsandlogic
    Thanks mate.
    I'll start on them as soon as I can find the sync springs on the carbs. My pops lost 2 of them, and nobody has a set laying around.
    That's the only thing holding me up from cracking them open and then installing them...i like to have everything when I do work on things.
    If i don't, they'll just be sitting around on the bench for another month or 2.
    Anyone have the springs for sale??
    It would save me : |
    #89
