Carb masters: 3rd gen still will not idle on pilot circuit with butterflys closed. Flooding into cyl
Discussion in 'Mechanics Garage' started by flummerylove, Sep 6, 2011.
  1. tinkerinWstuff
    You do not compensate for shorter needles in float level. float level is still float level and you set the height to match the spec in the book. You compensate for shorter needles by bending the tab on the float so that the needle closes at the right float level regardless.
    If there isn't enough adjustment in the float tab to set properly, you can compensate by shimming the needle SEAT with a washer.
    40 pilot jet should be ok to get running and not be the cause of the problem. Not to say the jet is 'right' or not - but the bike should run just fine with it.
    p.s. you'll offend my delicate sensibilities and make my girl parts hurt if you say fucked on VFRW
  2. flummerylove
    flummerylove New Member
    Utah
    40 slow jet
  3. flummerylove
    Utah
    I have pilot jets from a 96. They are marked 40S. They have one less cross hole drilled. Not in a hurry to fuss with jetting. Wise to mess with dat or not? All my floats have been quadruple checked, all are set to 9mm. This might be the tail chaser that let the previous owner to sell it...But NOT me! Quitting now would make my voyage thru hells gate in vain :crazy:
  4. flummerylove
    Utah
    Hey Tinkerin...all my inlet needle seats have crushwashers installed. Been there since I have owned the bike. Is this absolutely necessary? I thought it to be a good idea. That might be variable also..
  5. tinkerinWstuff
    crush washers should be there.
    what's on this thing for a fuel pump? Did someone install an aftermarket fuel pump with higher pressure that may be overpowering the needles?
  6. flummerylove
    Utah
    My main girl..a thing? Totally butt hurt :wink: Fuel pump is from a 96 VFR750. Same 900cc flow, correct? (please be the problem)
  7. flummerylove
    Utah
    would a bad fuel relay be an issue in this mix? *hmm...nix that idea.
  8. tinkerinWstuff
    '96 was also carb'd so fuel pump should be ok
  9. Yamarocket630
    Yamarocket630 New Member
    Here is a thought... is your fuel pump (3rd gens have a pump right?) providing too much pressure and overfilling the float bowls? If it has a pump, bypass it and run it without a pump. It should fuel lfine down to about 1/2 tank.
    Edit... tinkerin beat me to it...
  10. kennybobby
    kennybobby New Member
    Next time you pull the carbs try setting the float level to ~14mm and see if that helps. Even though the book says 9mm, you have a lot of nonstandard parts and the 96 pump, so maybe use the 96 float level. It should reduce the flooding issue and will bias all the fuel circuits toward the lean side.
    What do your mixture screw tips look like anyway?
    i have a 96 that is running 42 pilot jets--it does run on the rich side in Summer (no choke to start), but it will idle properly. The mixture screws allow adjustment over a range of at least +/- 1 pilot step size or more. If the screw tips are not damaged that is...
    The CBR900RR use a #40 pilot, but it is regular 40. That 40S is a special for the 4th gen VFR, and the number and size of the cross drilled holes in the emulsion tube is a critical factor is the mixture. Smaller diameter or fewer cross holes means less air in the emulsion => richer mixture. All the more reason to raise your float level and decrease the amount of fuel in the bowls.
  11. flummerylove
    Utah
    Copy that. Remember the small bore above the enrichment circuit fuel jet I asked you about? There is a plug in the bowl wall across from it per your pic. My fuel level is approx the yellow line. Is this ballpark? right_side.jpg
  12. flummerylove
    Utah
    I had wondered the same. I will add gravity feed to the to do list...
  13. tinkerinWstuff
    no - wrong ballpark
    someone please post link to pics of properly set floats....
  14. flummerylove
    Utah
    My mix screw tips look exactly like the good ones in this(your?) pic. Not pointed. Flat or perpendicular to the screw.
  15. flummerylove
    Utah
    Lower it is. Hints tinkerin?
  16. tinkerinWstuff
    hopefully you are setting your floats using a method similar to this:
  17. kennybobby
    Hell no, that is flood stage! But you have found the culprit...
    Don't doubt yourself tinkerin, that is a GOOFY line. The fuel level should be deep into the bowl, not up into the body. The floats ride on the top of the fuel, so the bottom of the float (the setting point) is where the fuel will be in the bowl.
    BTW i see you have the same need for a magnifying glass that i do, it's always sitting right there on the bench within reach...
  18. flummerylove
    Utah
    Yes my method is similar. Credit card tool.
  19. tinkerinWstuff
    then I doubt your fuel level is that high. That might be the angle that the fuel is but the fuel level would be somewhere near the middle or bottom of the float, not the top of them.
  20. tinkerinWstuff
    I'm out. on vacation for the next week. hope you have this sorted by the time I get back
