carb sync fail
Discussion in '1st & 2nd Generation 1983-1989' started by chuntera, Jul 13, 2011.
Tags:
  1. chuntera
    chuntera New Member
    Connecticut, USA
    I have an old motion-pro carb sync tool, with the mercury capilliaries and 5mm brass adapters. Last week one of the adapters snapped while on the intake port.
    I'm thinking I drill it out and heli-coil the threads. But the location is a PITA to drill and unsure how well a tiny 5mm heli-coil will work.
    Any suggestions ?
  2. bobthebiker
    bobthebiker New Member
    easy out first. it shouldnt be that difficult to remove. if it wont come easily, THEN get aggressive.
  3. Sparks
    Sparks New Member
    Hi
    How did you manage to snap one off ? I only do them up finger tight as they should have a little O ring to seal it. Any way ,as Bob said an easy out should sort it as is has a hole and shouldnt be that tight. Also try a bit of Plus Gas or WD40. Don't snap the easy out !
  4. tinkerinWstuff
    another vote for EZ-out.
  5. squirrelman
    Use a dremel to cut a shallow slot then use a small screwdriver to back it out.
    Or, if you can find exactly the best screw driver with the smallest point size and a taper near the edge, you might be able to wedge it in and get some turning traction.
    Or a hand-held drill bit might grab since, once the nut has gone, there's not much resistance to turning the screw.
    Don't want to be bothered now and make it a winter project?? Fill the hole in the adaptor with JB Weld and ride on........
  6. Dannyhoo
    Dannyhoo New Member
    Texas
    +1 on the easy out or you can try a left handed drill bit which has worked for me in the past with exhaust manifold studs
