Carbon Fibre Wheels For VFR800's '98 to '07
Discussion in 'Mechanics Garage' started by mello dude, May 2, 2007.
  1. APSengineer
    APSengineer New Member
  2. Badbilly
    Vinyl wrap and shelf paper.
  3. dino71
    dino71 New Member
    New Jersey
    I could not find anything specific for the 5th or 6th gen VFR on that website.
  4. safetypro10
    safetypro10 New Member
    Dallas, TX
    I found out that BBS racing wheels has a modular design and you can order a center section in 4 X 100 (Honda bolt circle) and than pick the inner and outer rims to make up a VFR rear wheel. As far as the front, I have no idea.
    Maybe contact Chip Foose and have some custom wheels machined from billet to your specs. Should be trick, and $$$$.
    Larry
  5. dino71
    dino71 New Member
    New Jersey
    Nope, I going to stay with my nice OEM rim. I thought there might be some wheels that were about 600-800 shipped but to pay over 1K for a rim is a little crazy.
  6. mello dude
    My understanding is an F4i wheel will fit, so any aftermarket for the F4i will fit the 5th and 6th gen.
  7. SAFE-T
    SAFE-T New Member
    An F4 wheel works as well, and you can use the VFR800 rotors. But you can't mix and match the rotors between F4 and F4i since the carrier bolt circle is a lot different. What you can do is put CBR929/954 and RC51 rotors on the F4i wheel, but I'm not sure why you would want to do that on a VFR800.
    One Frankenviffer owner on vfrD put Ducati 748/916/996/998 OEM rotors on a VFR800 front wheel for their RC51 front fork conversion.
    If you were doing a single-nut conversion on the back and you were going to retain the VFR's stock front end you could use a 3-spoke Ducati rear wheel with the F4 front wheel with VFR800 or F4 rotors as they look pretty closely matched.
  8. dino71
    dino71 New Member
    New Jersey
    I just found a like new F4i wheel near home and I was going to do that, I heard is almost 2 lb lighter than the VFR OEM wheel so i will post the results once I get it on......if spring ever comes to the northeast....
