Carbs! what is my problem???? HELP
Discussion in '1st & 2nd Generation 1983-1989' started by stunt700, Oct 27, 2008.
  1. supervfr
    supervfr Banned
    I agree. I just cleaned mine without taking the appart. I took out the jets and float to soak them separatly. but as for the carbs I soaked them while together, fliped then soaked again (one gallon of cleaner did not cover them compleetly) they are quite clean.
  2. Jimtt
    Jimtt New Member
    Chicago area
    Since the bike ran fine before you did whatever you did, it is safe to say the low and high speed jets are not the problem; did you replace the torn diapham?
  3. masonv45
    masonv45 New Member
    I'm sure the carb cleaner worked it's wonders on the fuel tube rubber O-rings.
    I hope you removed the pilot jet's rubber o-ring too.
    Must have been hard to remove the carb sliders with that plenum in the way. I've heard of people breaking or bending the needle at the end of the carb slider.
  4. supervfr
    supervfr Banned
    pilot jet's rubber o-ring?
    Couldn't find an o ring on any of the jets, the screwed and tightened directly into the carb body.
  5. masonv45
    masonv45 New Member
  6. SLOav8r
    SLOav8r New Member
    Central Coast, CA
    Clearly you are low on blinker fluid.
  7. Jimtt
    Jimtt New Member
    Chicago area
    There are none.
  8. supervfr
    supervfr Banned
    I see, I only took that out when i needed to push out all of the gunk.
    I have a question about this. If I am not mistaken I know what screw im looking at (wont know for sure until tomorrow) I thought this was a drain screw so I unscrewed it and then screwed it in all of the way. Is this why my bike wont run?
  9. supervfr
    supervfr Banned
    Perhaps not. I believe the screw that I took out was a drain screw as it i believe was in the float boal and the pilot needle is in the carb body
  10. supervfr
    supervfr Banned
    By the way. thank you for that link. I wish i had it to read through when i started, being the first time iv ever worked on carbs.
  11. derstuka
    San Diego, CA
    Sorry, I had to edit the title...the spelling was killing me. problume= problem
  12. supervfr
    supervfr Banned
    lol
    5678910
