chain replacement
Discussion in 'Mechanics Garage' started by v4pwr, Apr 4, 2008.
  1. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    They above views in no way represent the views of VFR WORLD or actual views of people that know how to install a chain the proper way. If the above post is used we will not be liable of maiming or death of rider. Using the above techniques may have side effects such as, scraped and burnt skin, internal injuries, bruising, loss of consciousness, bike total, hospital visit, crying and running nose.
  2. elf800
    elf800 Banned
    dallas
    lol :biggrin:
  3. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    The above post is representative of a person that has little self esteem and lacks that of REAL life friends who tends to apply himself to forums for medial attention. Do not blame the poster for lack of knowledge or over estimates his abilities as his frontal cortex is at fault. Thus we can only find amusement within his post rather than reality. I think I will start a new post so I will stop hijacking this one. Look for ELF AND WWFT (what would Freud think). Im sure we will go in depth with mother issues and societies abolishments. :smile:
  4. vfr70086
    vfr70086 New Member
    i could use that
    ive never done it before. i just got a 87 and couldn't tell you if it has ever been done
  5. v4pwr
    v4pwr New Member
    cleveland, ohio
    for all of those who care i did the best i could to put a post together. pics did not turn out as well as i would of liked ( crappy camera). see thread titled
    chain/sprkt repl. w/pics
    SLOVFR likes this.
  6. drewl
    drewl Insider
    Virginia Beach, Va
    The elf and wwft topic was already covered by myself in the 'nomination' thread. but I bet it could be explored further...there's plenty of material there.
    SLOVFR likes this.
  7. elf800
    elf800 Banned
    dallas
  8. elf800
    elf800 Banned
    dallas
  9. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    When he says permanent he means the rivet type, but you would have know this if you ever installed a chain on anything other than you 10 speed...:closed_2:
  10. JTC
    JTC New Member
    Watts, CA
    wrong thread i thought we were talking about whips and chains
  11. elf800
    elf800 Banned
    dallas
    :confused: :confused: :confused: :confused: :confused: :confused:
  12. elf800
    elf800 Banned
    dallas
    lol lol n lol
  13. VT Viffer
    VT Viffer New Member
    South Carolina
    Clip-type master links ARE available for the VFR. However, it is called out in the Honda service manual to NOT use this type of chain.
    It specifically mentions that the riveted type is the only style that is acceptably safe on the VFR.
  14. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    I have used the clip style on every chain I have replaced, and not had any problems. I bought an inexpensive chain press many moons ago when I started using O-ring chains, and just finally broke down and bought the entire tool kit including the riveting tool.
    The reason for buying the riveting tool is that the last chain I bought did not come with a clip-style master link, and it did not occur to me to check, so I had to make a 60 mile round-trip back to town to get one.
    When I think about it, though, it had been some years since I bought a chain. Professional ventures were occupying a lot of time, and I wasn't riding much. It could be that the clip-style links have always been an option, but I used to remember to ask for them.
    And is it just me, or does the master link never seem to have enough grease supplied with it? I always end up using an xacto knife to scrape a little more of some of the chain side plates to put on the links.
  15. elf800
    elf800 Banned
    dallas
    hers a website and a picture of your rivet type still use pliers and 8mm wrench a safety pin masterlink is better just my opionin www stores online.com ek screwtype master link ok there get sc:cool: rewd
  16. reg71
    Sikeston, MO
    yeah as RVFR said, it's the dry clutch. first time one rolled up on me I told him his bike was broken. :smile: I guess you get used to it. I hear that the Ducatisti are up in arms about the move to wet clutches that is upcoming... anyway, to get back on topic, I just did a chain replacement last year and it was my first time doing one without a clip master link. It was pretty easy and, providing you have the right tools, most anyone could do it. I bought the RK set that had chain and front and rear sprockets so that I knew they would match. There are two different chain styles for the VFR depending on if your front sprocket is the stock with rubber bushing or aftermarket without. As long as everything matches, it's not too hard a process and I think the owners manual even covers it. I bought the motion pro chain rivet tool but I imagine they are all about the same.
  17. Rat
    Rat New Member
    Portland(ish), Oregon
    I politely, yet vehemently, disagree with SLOVFR's apparent point-of-view regarding elf's procedure.
    That's exactly the way I've done it for many years with clip-type master links on many powerful bikes ridden very hard & very fast (Autobahns, Nurburgring, Spa, etc.), with never a problem - when performed carefully and correctly.
    * I clean and lube my chain(s) frequently, including a quick visual inspection after every ride.
    BTW - a hacksaw with carbide-tip blade (about $10) will remove the old chain inexpensively, albeit somewhat slowly and laboriously (compared to a Dremel-type tool).
    Ultimately, one could purchase a complete OEM "endless" chain and sprocket kit ($$), and remove the swingarm (involved, but not too difficult) for installation.
    **No, I haven't bothered to read this entire thread (too much drivel); I balked when I got to this point and felt obligated to comment/rebut.
  18. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    Hey if you want to run a clip ..... thats up to you. Ill take the extra precautions and rivet all of mine.....
