Chain slack for Gen 6
Discussion in '6th Generation 2002-2013' started by violetfusion, Dec 8, 2015.
  1. violetfusion
    violetfusion New Member
    Singapore
    Sorry for the stupid question.I understand the chain slack for Gen 6 is approximately 1 inch.
    I have inconsistent reading when I took difference reference point between the swingarm and the drive chain.
    Where should i take the measurement from?Green or red line?
  2. Terry Smith
    Chain slack is measured at the mid length of your chain, i.e. halfway between the sprockets. The slack is the total up and down movement. My advice is to err on the loose side, as a too-tight chain wears itself and sprockets faster. Many chains develop a tight spot so if you have that, rotate the wheel until the lower chain run is at it's tightest and set the tension in that position.
  3. squirrelman
    If you feel a series tight-then-loose spots or your chain and sprockets are more than about 20,000 miles old, you need all new parts. You'd need to spend at least $160-$180 for a quality setup.
    As cad says ^^ find the tightest spot, and set tension correctly at that place. :sneakiness:
  4. fatshoutybloke
    fatshoutybloke New Member
    Essex, UK
    And don't forget, VFRs prefer it slightly loose.
  5. 34468 Randy
    TC likes his wimin that way too.
  6. RVFR
    LOL to answers the original question, I'd say between those two spots pictured. so it must be the yellow one huh?
  7. Turkish rider
    Turkish rider New Member
    Turkey
    Turkish Republic
    Hi
    my 2003 model's chain is a tad on the tight side my Turkish mechanic thought it would stttretttchhhhhhhhhh, but 5000 ks later still tight, do I tell him to slacken it off? Should be an inch slack midway between the two sprockets about 2.5 cm right?
  8. Knight
    Knight New Member
    USA
    Yes tell him to go slack off.
    Right the spec is something like .8 - 1.2" and it likes it nearer that loose end of the spec.
  9. 34468 Randy
    Totally agree with this. You are subjecting your chain and sprockets to far too much strain and pressure when it is too tight. Keep in mind, soon as you sit on the bike and compress the suspension, the chain does tighten slightly anyways. Also. Chains don't stretch. Links and sprockets wear. I think I would also be seeking out a mechanic who knows a little more about bikes.
  10. Badbilly
    And OB-GYNs that will take an extra stitch in loose women.
  11. sunofwolf
    sunofwolf New Member
    1.5 inch, too tight will wear chain faster, also you can tell if too tight by riding it or too loose. The wolf knows best on the theory of everything.
  12. Turkish rider
    Turkey
    Turkish Republic
    Yeah, you guys confirmed my worst fears,apparently the excuse he gave initally was that with an extra link it was too loose and he made I ride it for a while suggestion, but after 5ks it was still the same, so he has finally relented and is going to fit an extra link, if I am not satisfied with that, well just gonna have to take my custom elsewhere,he knows his way around a bike, even races a few but sometimes I think a bit of commonsense is in short supply. Turks are like that! Spoke
    to him last night and now the story has changed, when the chain with the sprockets were presented to him by myself coz I bought it from the main Honda dealer, he said,,,, wait for it,the chain was barely long enough to fit, so instead of making a phone call tot he dealer he made it fit,, too tight,, that was in September 2015. Needless to say when I get it back from him,,,,,,,,,waiting,,,,,,,,, waiting,,,,,, plonker,,,, twat,,,,,, waster,,,,waiting,,,,,,shit head,it will be for the last time!
  13. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    .... this is why I do everything myself if possible.
  14. gade-thrasher
    gade-thrasher New Member
    I can't understand how you can get an accurate measurement on chain tension. Even on the tight end of the spec, the chain touches the swingarm when pushed up. So between that and pushing down on the chain to get a slack measurement, how do you know what the real measurement is when you can't get the full range due to hitting the swingarm? Am I making any sense?
  15. sunofwolf
    Ya like me, too loose with also wear and could just snap
  16. 34468 Randy
    I've heard you were too loose.
  17. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    It's probably from wearing his chaps backwards in front of all the Hardley Dudes.
  18. GreginDenver
    GreginDenver New Member
    Denver, Colorado
    Another thing to remember: The recommended chain slack is a protective measure. If the chain is too tight it can put stress on the bike's gearbox bearings, especially on the output shaft bearing (the one that is right behind the counter sprocket).
  19. Turkish rider
    Turkey
    Turkish Republic
    Update:
    Well spoke to my Turkish mechanic, it gets worse, to cut to the chase, he took the chain off and went a got another link to slack off the chain, but he ordered what he thought would be the right part without checking it first, like taking the chain to the local Honda dealer and saying something intelligent like "got a link or two to fit this"? No, he just did his own thing and guess what?? The part he ordered doesn't fit, so instead of taking it back sans chain he decides to try and make it fit into the end of the chain,,,, how you may ask will he get a small piece of highly engineered hardened steel to fit into a small space that it was not meant to?? Give up,, yeah, I would never have guessed the answer,, with an angle grinder of course!!!!! Now what that will do to the integrty of the chain should he ever get it to fit god alone knows! Needless to say, when my machine, the poor sweet thing is returned to me, it will be taken somewhere else to have the job done as it should be, instead of butchered and bodgered by an idiot, no doubt he will present me with a bill for the work, sorry damage he has done!
  20. MichaelD
    MichaelD New Member
    Central Kansas
    If memory serves me, 110 links to the chain.
    Your mechcanic is a joke.
