Chain Waxing Made Easy - 101
Discussion in 'Mechanics Garage' started by Wabbit1961, Apr 5, 2008.
  1. Hotbrakes
    Hotbrakes New Member
    Richmond, VA
    whoops
    dangit...hope the 7th generation comes with an automatic transmission...don't lube the chain in gear...its hard to work the clutch with only your pinky...and use capital letters and anything that requires the shift key...
    i wish i would have used my right hand...then i would still be able to use the front brake since its linked to the rear...maybe i can switch the clutch to the right side
  2. Mainjet
    Mainjet New Member
    Southern Ca.
    Yes Texas, when you switch to chain wax you need to clean the chain. I use WD40 sparingly and plenty of rags.
  3. PuCaudata
    PuCaudata New Member
    Great Falls, Montana
    I use Bel-Ray chain lube and it works great. No throw-off and lasts as long as I'll ever ask it to.
    I'm imagining that lube or chain wax is applied in roughly the same manner. Having the drivetrain engaged and running while on the centerstand is already dangerous. Putting your fingers anywhere near the rear sprocket and/or chain while the bike is in this state is insane.
    Is it that difficult to simply spin the rear wheel manually while applying the lube/wax? Difficult enough to warrant possibly giving yourself a "lobster claw" for a hand?
  4. RVFR
    FWIW I don't get my fingers nor hand really anywhere close, that's what the little nozzle tube is for.
  5. PuCaudata
    I don't know what "FWIW" means...:confused:
    I understand the physics involved, but I still don't understand why the motor has to be running and the drivetrain engaged. Oh well...to each their own, I guess. Just be safe. Cool? Cool.
  6. RVFR
    "For What It's Worth" is cool, like you said, to each their own.
  7. mello dude
    Jeez, this thread is as bad as an oil thread.......
    You know - Its really not that hard to sit down on the mechanics creeper and hand rotate the wheel. A full chain rotation takes what - a minute? And any spray stuff I can hand throttle fast or slow, depending on my mood. Also while I'm sitting there I look around at other stuff too.
    MD
  8. Wabbit1961
    Wabbit1961 New Member
    Hudson, Florida
    I cannot believe how many of you don't know how to read a simple post. The step-by-step instructions are very clear as to what you do and WHEN you do it. If your chain is dirty, then yes, clean it manually with the bike on its center stand and OFF in neutral so you can rotate the chain. Then start the bike, put it in gear, put the cardboard behind the chain where I show in the pics and apply the wax. Buff the excess wax off with the bike OUT of gear and the engine SHUT DOWN by MANUALLY rotating it with the cloth in your hand, pulling the chain along as you do so. My method is NOT dangerous in any way, shape, or form. My hands never go near the chain while the motor is running and the bike is in gear.
    For those of you that disagree and think it's dangerous, do it your own way and stop wasting thread space.
    Anyone with an honest question about this can always send me a private message.
  9. nvoges
    nvoges New Member
    Columbus, OH
    Wd-40
    For what it's worth, I've read that you don't want to use WD-40 or equivelant on an o-ring chain because it will degrade the o-rings and allow the oil out. I'm not sure what the o-rings are made of, but this may be true.
  10. 34468 Randy
    I use PJ1 and have done so since I started riding....way back in July 2006. It has served me well as far as a lube goes. I put on about 5,000 KM a month. But it seems to gather the much and collect on parts underneath, then drip onto the garage floor. Then I promptly step on it and walk into the house and re-decorate the carpet. Wife gets sooooo pissed. Go figure.
    So I am going to try that wax for a while. Will clean the chain with WD40 and high pressure hose. And I am not going to tell anyone how I put this stuff on. Don't want to rekindle the heat here.:peep: :fear: :target:
  11. 34468 Randy
    I have used WD40 to clean the chain many times then pressure wash the chain off at the car wash. A 1 1/2 mile ride home then re-lube. I got 45,000 KM out of my chain and sprocket so I figured I did OK on that. Or did I. I am too new to know for sure.
  12. Shikyo
    Shikyo New Member
    Vancouver, BC
    "high pressure hose"
    I think better not using a power washer on o-ring chains.
    I have been using Maxima Chain Wax since 1993 and I don't want to
    use any other lubes. I am too lazy so I just spray rollers and insides of plates
    while bike is on the centre stand and after I come home from a ride. I never wipe chains
    after I spray nor use a cardboard too shield off the rear wheel. I use a skinny
    nozle and watch carefully so that I don't spray anything else. I spray very close
    and so that the tip of the nozzle almost tuching chainlinks. In my case I don't keep motor
    running since I do this in my garage. My out sides of chain plates are not as shiny as Wabbit's,
    however, much cleaner than lubed with oil.
    I ride bicycle (Colnago C40, Litespeed etc.) and I have used Whitelightning fo 14 years.
    After I lube, I wipe wax off from plates and rollers vigolously. Maxima Chain Wax is much
    cleaner than Whitelightning chain wax.
  13. terdog
    terdog New Member
    POLLOCK PINES, CA
    More than a few miles and a few bikes have taught me a couple of things.
    A clean shiny chain is a good thang... especially if it gets you to actually inspect the chain for defects/malfunctions (ex. lost Master clip, cracked side plate)
    An O ring or X ring chain are best for most riders, street or dirt.
    The rings will de-grade with a constant over use of WD40.
    The rings hold in the grease, so "lubeing" is for keeping the chain rust free, and giving a bit of lubrication to the ring / sideplate interface.
    The best time to lube is AFTER your ride, when the chain is its warmest. The worst is just before your ride. Anytime else is ok, as long as the carrier agent has time to evaporate.
    High Pressure washing is not the best way to clean it. If the spray wand is adjustable, open up the spray patter to minimize the pressure. I have settled on spraying it with Castrol Super Clean, running a grunge brush over it, hoseing off and then lubing.
    BUT, this is a professional rider on a closed course, and your mileage WILL varry. (lol)
  14. 34468 Randy
    So having read his one and Shikyo's post, am I wrong in how I deal with my chain. Is 45,000 KM too early to be replacing a chain and sprocket. I really don't know. My Mechanic tells me I did well getting that kind of mileage out of it but then he has alternative motives. He gets my money for a new one. I simply do not have the experience with motorcycles yet to know if I did OK by this chain.
    What I can say, and I know bicycle's and motorcycles are two different beasts, this is exactly how I kept the bicycles cleaned and lubed. And I put mega miles on them for well over 17 years. I made one chain and cog change on my Rocky Mountain after riding it for about 10 years.
    Your thoughts gents.
  15. Shikyo
    Shikyo New Member
    Vancouver, BC
    "45,000km"
    Very good if you can ride 45,000km. I think you have to start thinking at around 30,000km. It depends how you ride. Young people who do wheely make chains strech faster even if chains are maintained properly. People ride dart bikes expect replacing their chains at 15,000~20,000km. I ride very slow and smooth, so my bike doe not
    ware out chain at 30,000km.
    I heard and read power washer may injure o-rings. Bicycle chains don't have o-rings, so
    they might be able to washed with power washers, although washers could be strong enough to blow side plates off or bend chainlinks. Before O-ring chains were invented, we had to change chains at around 10,000km.
    I replace bicycle chains at around 4,000km, so that I don't need to replace $450 cassette each time.
  16. ZonaMan
    ZonaMan New Member
    Tucson
    I rock the PJ1 Blue label. It's great! I clean my chain with Prep-all. I do it after a ride home from work whenever it's lookin a little dank.
  17. terdog
    terdog New Member
    POLLOCK PINES, CA
    Randy, I'd say that your doing pretty good. Like Shikyo stated,it all depends. There are too many factors to chain life. Engine size/hp/torque, riding style, chain grade, etc.
    I think that chains are like a lot of other things in modern motorcycling... we are truely blessed as things get better and better.
    Randy, sleep well, you got it under control.
  18. 300shooter
    300shooter New Member
    armpit of ontario (Windsor)
    I use the same wax, my dealer here said it's the best they've used and these are guys that ride every day. They had more expensive ones but said I wouldn't be as happy with the guck slinging around.
    As far as the method of application, I'm pleadin' the 5th.
  19. Bartman-eh
    Bartman-eh New Member
    Ottawa, Canada
    There is quite a bit of debate about using WD-40 to clean o-ring chains. There are 2 reasons why I don't use WD-40 to clean my chain. [1] there is debate about whether WD-40 may or may not damage o-rings so best to avoid it and [2] the risk of over spray or drips of WD-40 getting onto the brake pad and rotor area are too risky. It is a lubricant after all so getting on the brakes is a really bad thing.
    Kerosene gently applied with a soft bristle brush seems to be the best approach. I know some of you have read not to use a brush as this can damage o-rings, but if a soft brush is used softly, I don't believe there is any damage done.
  20. Wabbit1961
    Hudson, Florida
    The thing about WD-40 is that it cleans AND lubes. I have no fear about using WD-40 to clean a very dirty chain, and if you apply it to a rag it does a damn good job cleaning your wheels as well. No, I don't get it all over my tires and brakes, I apply it to a rag and then rub the rims. Nice n shiney :treehugger:
    What you don't want to do is use any engine or electrical parts degreasers! They can deteriorate seals anywhere they make contact. That's a no-no!
    I have to say Honda gave me a damn good chain. I have 12,000 miles on it and I have YET to adjust the chain! It's still nice n shiney too!
    I do have a question for those that have done this already. How many miles should one expect to get out of the brake pads on this bike? I don't ride hard. I mostly commute. I only weigh 175#. I just brought my bike in to my local mechanic, one that I have trusted with numerous bikes (including my 1982 Yamaha Seca 650 Turbo), and he suggested it's time for me to replace the pads on my next oil change (15,000 miles). He did say not to worry and that I have plenty of pad left, but that it would be wise to change it at that time. Compared to other bikes I have owned this is kinda low in my opinion. I think because they bike is so heavy for it's block size perhaps, and so front heavy to boot. These are the stock pads from Honda. He's going to replace the pads with EBC.
    I am also having the air filter replaced with a K&N at that time, along with a change of the plugs and inspection of the plug wires.
    I have 4,000 miles on my Metzler Racetec Z6's and they have way more than 2/3 the tread left so far, with no hardening of the center of the treads. I love these tires! BatlAx SUK!
    One last thing, I am having the plugs changed and wires checked cause it seems my fuel mileage has decreased enough for me to notice. I haven't really noticed any performance problems except an intermittent stall of acceleration when I start off cold from work to go home in the heat of day. I crack the throttle a bit harder and it comes back to life. I think it may be a clogged air filter, or a fouled plug. At least I hope so. I put STP Octane boost in the bike and OMG! Yeah, I overdosed it and put the whole little bottle in all at once (it's made for 21 gallons, not 5.8), but DAYUM! The front tire comes off the ground and I wheelie when the four barrels kick in. It used to barely pull the wheel off the ground. Today I had to back off cause the front would have kept climbing upward! I only plan to do that this one time in an effort to clean out the tank and lines a bit. I think it worked! *lol* Fuck, I need to get it tuned to do this on regular fuel! Btw, my mechanic said not to do it, but i had already bought it. Waste not, want not. He said it can degrade a lot of the fuel system and should not be used, nor should their fuel injector cleaner.
    Stan
    P.S. - I love this fuckin' bike!
