Cleaning 20 year old dirt in engine bay
Discussion in '5th Generation 1998-2001' started by OnlyVfr, Oct 25, 2020.
  1. raYzerman
    raYzerman Member
    Millgrove, ON
    I use Simple Green. Seems to work well. Spray it on, let it soak for a bit, brush, repeat if necessary. Use a combo of SimpleGreen, dishwashing soap and water in my ultrasonic cleaner.
  2. mello dude
    What ultrasonic cleaner you got? I've been thinking about adding one to my garage..
  3. squirrelman
    the HF cleaners don't last long :eek:
  4. mello dude
    HF is not on the radar..
  5. raYzerman
    raYzerman Member
    Millgrove, ON
  6. fink
    fink Member
    Some pics from my ZX9r restore/build. Used mostly paraffin/diesel, wd40, brake cleaner, soap n water in conjunction with good old elbow grease , scrubbing brush and electric toothbrush thing for car wheels. Zx9 E1 rebuild 005.JPG Zx9 E1 rebuild 011.JPG Zx9r e1 007.JPG Zx9r e1 013.JPG Zx9r E1 Carb Strip 020.JPG Zx9r Exhaust studs 009.JPG Zx9r e1 004.JPG
  7. motd
    motd New Member
    I came to say that I also use Simple Green, with a wire brush. Let it soak for 5 min, go at it with a wire brush, break it up, wipe up, go for a 2nd round, then think about briskly using some carb cleaner here and there. Thats what I used for the area around the chain/swingarm filth that was just as old looking as yours. I have a feeling there are suggestions here that may work better but I will say that I was very surprised how good it worked, but you need the wire brush.
    OnlyVfr likes this.
  8. squirrelman
    since it looks like water got into the one cylinder where the intake looks rusty, you may have bad piston rings and a corroded cylinder, so the bike may never run right. was it stored with carbs removed ? suggest a compression test b4 you do much more work.
  9. DaHose
    DaHose New Member
    Napa, CA.
    Some PB Blaster in the exhaust port, down the intake, and through an open spark plug hole on that cylinder is probably a good idea too.
    Jose
  10. OnlyVfr
    OnlyVfr New Member
    Ireland
    I eventually used acid for aluminum... drill and few different brushes...
    VFRIRL likes this.
