if you plan on switching to clear on the rear a turn signals the fronts just snap apart but the rear if you are willg to take you time can be separated with a heat-gun and a dull butterknife gradually work from one side after you soften up the adhesive up all around and if will seperate and you can use the black housing without having to do any electrical wiring and you will be able to use the same bulbs as before i hope this helps if any decides to make this change just remember to move the hat gun around to keep from melting the plastic housing
