Coolant in Oil, feeling pretty sick right now
Discussion in '1st & 2nd Generation 1983-1989' started by jrob_28, Nov 6, 2010.
  1. donald branscom
    donald branscom New Member
    Guerneville CA
    A new Ducati is $20,000- 30,000 or more.
    Of coarse it is built like a swiss watch.
    #41
  2. tinkerinWstuff
    None taken. And if it was my motor, I'd have it tore down and repaired in a day. But an internet forum does not a mechanic make. To encourage someone to rebuild a motor who may not have the skills to begin with is not doing them any favors. We are not there to offer tools and assistance - only flawed internet advice because we aren't there to see what's really happening. If the guy lived up the street from me then the advice would be different because if I convinced him to take on the project, I'd be there to hold his hand.
    In this case, advising him to jump off a cliff without being there to jump with him is not doing the guy any help.
    Internet forums don't make surgeons or mechanics.
    #42
  3. invisible cities
    invisible cities New Member
    new york
    Fair enough!
    #43
  4. squirrelman
    HOW did i know b4 clicking on that this thread concerned a VF 500 ???
    The crank bearings are likely damaged and maybe the crank itself, depending upon how long it ran with a water/oil mix.
    Admit defeat this time, part it, and look for a newer bike.
    The recommendations above for a replacement bike are good ones, especially the NT 650 and the EX.
    #44
  5. tinkerinWstuff
    Where have you been? leaving me here to piss off the 1st genners[​IMG] all by myself. Feel like I've been bursting dreams all alone for a week or more.
    #45
  6. slowbird
    slowbird Member
    Toronto, Ontario.
    I've helped a bit.
    Though I'm beginning to feel the need to piss on 2nd Gens too.
    .....but that could be the beer and watermelon :confused:
    #46
  7. donald branscom
    Guerneville CA
    I have taken apart many engines and with blown head gaskets and the crank bearings were not ruined. It could happen if rode for a couple years that way. I have not seen that happen. Water will not mix with the oil. It usually goes to the bottom of the oil pan. The oil pick up tube is not on the very bottom of the sump.
    If the oil light is flickering that could be a sign of low oil pressure from coolant.
    #47
  8. tinkerinWstuff
    dissagree. Do a search, milky oil. What is that? Oil that has mixed with water. Once the engine sets for a period of time, the water and oil will separate back out and the water sets on the bottom. You can't run an engine with water in it and think it's going to just sit there happily on the bottom without traveling past your bearings.
    granted, depending on how long he ran it for the bearings might be just fine. But it's one more 'what if' for that motor.
    #48
  9. donald branscom
    Guerneville CA
    I agree that a complete tear down is best. And we do not know the milage.
    But if the pan comes off of the bottom and the cases split horizontally like the VF1000R, then it is easy to check the rod bearings.
    On an engine with blown head gasket, when you pull the oil drain plug usually you will see green coolant first before the oil com out of the drain hole. The milky white oil is usually in the radiator. But I have seen milky looking oil in engines from condensation too. Like in the desert where there are extreme temperature differences in day and night.
    And the engine is just used for short trips.
    For me a blown head gasket has three things present.
    Coolant in the oil drain pan.
    Low compression.
    And oil in the radiator.
    Also overheating.
    #49
  10. slowbird
    slowbird Member
    Toronto, Ontario.
    Maybe if it was a different bike, but for a 1st gen there are too many unknowns.
    You can pull the engine apart and fix everything....spend lots of money but you still have a motor that you can't push to the edge, and you need to constantly babysit the valvetrain to watch for problems.
    .....and you may still drop a valve.
    Donald B, how many VF500 motors have you worked on?
    #50
  11. donald branscom
    Guerneville CA
    I have not worked on that 500 engine,but I have worked on many "problem"engines.
    I just fix all the problems.
    It does not matter to me how many engines another person has worked on.
    When i work on an engine i go over the engine part by part and fix everything I see that looks like trouble. I make it better than when it came from the factory.
    If it has a known issue I fix it, and get advice from machinists for the best possible solutions.
    I would much rather rebuild a engine than to go get a used engine that could have the same ,or even more problems. I always want to know exactly what I have.
    Stop being a bully. And get rid of that child bully avatar too!! LOL
    #51
  12. tinkerinWstuff
    We aren't talking about you donald. If it were you and your engine, I wouldn't have any argument.
    #52
  13. ridervfr
    You better get a job as a counter person at the local Honda shop or otherwise when you find out how much all the parts are gona cost youd better be sitting down or at least have a chain on your wallet cause the money will be flying.
    You have to know when to walk away from some things, BTW The Donald, my Ducarti 900 SS had that trelis frame and it was bent like a banana, I still sold it on Ebay along with a title. Wonder what the hell that nut was gona do with it>? Steal another bike and re-assign the papers? Anyway, have fun and dont go broke...CHeeRss
    #53
  14. crustyrider
    crustyrider New Member
    North Country, New York
    huh oil in the radiator? never seen that one...and I've ruined plenty lf motors....the only time now that I think about it that I saw oil in the "radiator")( actually the water jackets) was when I blew the engine in my boat... it had a crack in the block in one of the water ways....The block filled up with water in a few short moments. when I removed the intake manifold it was completely full..........ruined engine......but that was because the block had frozen. over the winter.....
    #54
  15. slowbird
    slowbird Member
    Toronto, Ontario.
    The problem with these bikes is the fact that you cant fix all of the problems. The valve springs are an issue and you'll need to make custom ones...which costs money. With the custom valve springs you now have to make sure the super soft cams and rockers don't wear out.
    If you're gonna spend that kind of Ca$h on a motor I wouldn't do it on a 1st gen.
    I agree with the above statement, but not in the context of a 1st gen. Either way you lose. You spend waaaaaaay too much money to make the motor better, or you get a used motor and it grenades down the road.
    #55
  16. invisible cities
    new york
    Respectfully you can fix 'em.
    I do think Tink's point that many owners are not up to this challenge and would be better served by purchasing a newer bike is valid but,,,for those who enjoy owning and working on vintage motorcycles the VF500F is a great bike to have in the stable.
    #56
  17. squirrelman
    Sorry, Don, but i've seen an oil/water mix come out of engines in two ways. First way has oil with green cooloant floating on top, obviously not mixed. Second way drains a light chocolate frothy goo that resembles Starbucks double latte, and that, i believe, is water well and truly mixed with oil !! Mixed as inextricably as money and politics.
    >>>>>redacted and withdrawn<<<<
    #57
  18. donald branscom
    Guerneville CA
    Nice bike!!!
    I really like it.
    #58
  19. donald branscom
    Guerneville CA
    I agree about the chocolate stuff.
    But oil floats on the water.
    Try this.... take a glass jar and pour coolant in it. Now put engine oil on top. See what I mean?
    Why do you think they say NEVER put water on a gasoline fire? Same thing , the fire just spreads out. Gas floats on water. Just like in your gas tank. The condensation collects on the bottom of the tank.
    #59
  20. slowbird
    slowbird Member
    Toronto, Ontario.
    You can?
    When I was researching parts for my 86 VF500 I couldn't find parts to replace all the flawed VF500 parts.
    There are places that sell better quality VF500 Valve-train parts for all 3 years of the VF500.....even the 86?
    ....and importantly.....affordable parts?
    #60
