cracked fairing, how can i repair it?
Discussion in '1st & 2nd Generation 1983-1989' started by Rudydereza23, Jun 18, 2020.
  1. Rudydereza23
    Rudydereza23 New Member
    dropped my bike today and the fairing cracked. whats the best way to bond it back together? would JB weld work? are these fairings made from ABS plastic or fiber glass?
  2. Terry Smith
  3. Rudydereza23
  4. raYzerman
    raYzerman Member
    Millgrove, ON
    I have used Permatex Plastic Epoxy for many repairs, the Plastex solution looks very good also. JB weld stuff is runnier and not as strong.
  5. straycat
    x 2 for Plastex.
    I use it A LOT
    you can get it in different colours as well so it helps when you dont want to paint the repair area for only 1 crack.
    Make sure to use a good metal tape on the front finished side of the fairing, v groove the back side and use the plastex. The metal tape will help prevent the plastex from bleeding through to the front side and should make the repair almost invisible on small repairs.
    Your is a sizeable repair but Id still use plastex it works very well. Use in a well ventilated area though.
    Rudydereza23 likes this.
  6. VFR4Lee
    VFR4Lee Member
    Reseda / LA
    Boomtank likes this.
  7. Rudydereza23
    ended up fixing it with permatex plastic bonder and some drywall tape
    Bazza and Terry Smith like this.
  8. VFR4Lee
    VFR4Lee Member
    Reseda / LA
    Custom engineering. :)
  9. skimad4x4
    France
    French Alps & London
    Plastex for the pretty stuff but if you have broken lugs this might be worth reviewing...
    SkiMad
    pipet likes this.
