Crispy stator.
Discussion in 'Mechanics Garage' started by Mousejockey, Apr 27, 2015.
  1. Mousejockey
    Mousejockey New Member
    Manchester UK
    Got meter on order should be here next Monday :)
  2. H3nry
    H3nry New Member
    Pflugerville, TX
    I remember a long time ago Suzuki had a stator overheat problem and part of the dealer fix was to drill out an oil hole for more cooling oil spray into the alternator housing. I see lots of people giving attention to stators, but I don't see any posts regarding cooling the stator. I would suggest making sure the new stator is in good thermal contact with the cover and that oil spray onto the stator isn't blocked by wires, etc. As you can see, one side of the stator looks new, the other side is cooked. Why? The electrical load is supposed to be evenly distributed. Was one of the yellow wires open, leaving 1/3 of the coils offline and placing the whole load on the rest? Was cooling oil not getting to half? Something wasn't right...
  3. Allyance
    Allyance Insider
    Germany
    East Bay, California
    Cleaning up my old 83 VF750 today and took the fuel pump/ rectifier assembly out, and sure enough Honda used a smaller 3 pin connector on the stator wires and it was showing signs of corrosion!!! You think they would have learned after 30 years that system doesn't hold up!
  4. NormK
    NormK New Member
    As long as they last out the warranty, it isn't Hondas problem
