Cylinder head and cam cap torque specs 1986 VF500F?
Discussion in '1st & 2nd Generation 1983-1989' started by phranticness, Dec 3, 2021.
  1. phranticness
    phranticness New Member
    Lower Lake, CA
    I'm replacing head gaskets on a 1986 VF500F. Can someone check the manual for the head torque specs please? I don't have a manual.
    I need the torque specs for the cylinder head bolts, Cylinder head nuts, and camshaft cap bolts
    Everything else I can just tighten by feel. I've got the heads, tensioners, and cams/caps installed, I just need the torque specs.
    Thank you.
  2. phranticness
    Lower Lake, CA
    I thought I should mention that I looked through the stickies and tried google, I can't find a link to Clymer or Factory manuals. Lastly, I really appreciate your effort if you post these specs for me and hopefully this post will become a google result for the next guy.
  3. Terry Smith
  4. phranticness
    Lower Lake, CA
    Thank you! I really appreciate the link too. Hope it helps the next guy as well.
