Dead Electrics at a stoplight! 6th Gen
Discussion in 'Mechanics Garage' started by Voided76, Jun 14, 2014.
  1. Voided76
    Voided76 New Member
    San Diego, CA
    the right rear turn signal won't light up off the harness.
    the left Will, if I plug the right light into hte left harness, it lights. the plot thickens.
  2. Voided76
    Voided76 New Member
    San Diego, CA
    I'm seriously on the verge of giving up.
  3. Allyance
    Allyance Insider
    Germany
    East Bay, California
    If one light is brighter than the other, the dimmer one is finding it's ground through another light or device.
  4. Voided76
    Voided76 New Member
    San Diego, CA
    I had a spare flasher relay laying around. turns out that is what was doing that.
    bad news is, bike's still down for the count. it's going in a local shop prolly tuesday or tomorrow. ugh... insult to injury.
  5. FMB42
    FMB42 New Member
    I'd start be checking every ground you can find (now would be a good time to refer to the factory service manual wiring diagrams).
    Pay extra attention to any grounds that terminate on the aluminum frame or engine cases due to corrosion between dis-similar metals (steel ground wire connector mounted to aluminum can lead to excessive corrosion).
