Delayed reaction when turning throttle.
Discussion in 'Mechanics Garage' started by anarchy13, Mar 4, 2011.
  1. tinkerinWstuff
    I'm traveling this weekend and won't be around VFRW. You should take some video of the sync gauge before, and after. I'm optimistic that it will be the majority of your problem and it would be interesting to see/hear the before and after.
  2. anarchy13
    anarchy13 New Member
    Germany
    Will try to do a vid man im hoping the sync will fix most of my issues also, mainly the throttle issue about the engine not reacting like it should when turning the throttle and letting go. The slowly speeding up and going back to idle when it should be much faster. Im still waitin on special tools to come in the mail then ill get er done ;)
  3. anarchy13
    Germany
    Hey man how u doing? i think the boots are leaking any way to seal em without removing the carb? Thanks for all your help :)
  4. betarace
    betarace New Member
    Middleburg, VA
    look @ the clamps on each, try to tighten. Boots are cheap (like $10-12 each) should you need to replace them
  5. anarchy13
    Germany
    Know some good websites to order from??? Ebay doesnt have the ones for my model.
  6. betarace
    betarace New Member
    Middleburg, VA
    servicehonda.com
    ronayers.com
    or david silver spares in the UK
  7. tinkerinWstuff
    check price online, support your local dealer. Your local dealer price will likely be the same when you factor in shipping from online retailer.
  8. betarace
    betarace New Member
    Middleburg, VA
  9. tinkerinWstuff
    now you're just showing off
  10. betarace
    betarace New Member
    Middleburg, VA
    some people call me the space cowboy, some people call me Maurice, some people call me a dick
  11. donald branscom
    donald branscom New Member
    Guerneville CA
    Same old story... Clogged idle jets. Bike sits and they get clogged easily.
    But no one wants to take the cabs off to actually remove them and clean them and make sure you can see day light through them . They just want to spray something or replace some easy to get to part. But take off the carbs NO.
    Can be confirmed with a vacuum guage. If you know how to use it.
  12. anarchy13
    Germany
    well finally got the tools to sync and gap so ill get back to u on these questions ;)
  13. anarchy13
    Germany
    just to let you know none of these jokers would send to germany cept for david spares but somethin wasnt right there either cant rememeber!! anyways im havin a hell of a time finding new or good Honda parts here in Germany alotta used boots on ebay tho!!!!!
  14. anarchy13
    Germany
    Hahahahahahaaa thats a good one!!!!! ;) thanks for all the ebay links guess you were step ahead of me just wrote u that i know about all the boots on Ebay and ya most people on Ebay will send to me in Germany but used boots cost almost the same as new ones and then i may just have the same problem I got now all over again? the boots i have now look as good as any ive seen on ebay thats why im saying there has to be a trick to seal em abit better besides just tightening the clamps???? GLUE? SILICONE? TORCH? Hahaha
  15. anarchy13
    Germany
    I hear ya well carbs have been overhauled meaning used a carb kit on each of em. Bike finally started for the first time after i did that but runs like crap. hanging idle. i let go it just idles on. i give it gas it takes forever to pick up. cables ok. found atleast one leak in a carburator boot. trying to seal it or find new ones which s kinda hard here in germany if u speak better english like i do! once i figure out how to fix this air leak hopefully without having to buy new boots i will do a carb sync and adjust the valves and i hope that does it!!!! cross your fingers for me!!!!!!!
  16. donald branscom
    Guerneville CA
    You do not need the special carb boots. (Ebay)
    They do not work that well even when new.
    I use the silicone boots made for turbo systems.
    You can just cut them to length. Different colors available too.
    The carbs are easier to install with the more pliable silicone rubber turbo boots.
  17. anarchy13
    Germany
    Now that sounds like a plan where do i get a strip of that stuff?????
  18. donald branscom
    Guerneville CA
    Re read the post.....Ebay. Type in turbo boots. I think I ordered two and cut each one in half.
