Destroyed my Swingarm, take my advice.
Discussion in '1st & 2nd Generation 1983-1989' started by JasonWW, May 19, 2013.
  1. JasonWW
    JasonWW New Member
    Hou. TX
    #61
  2. JasonWW
    JasonWW New Member
    Hou. TX
    THREAD DONE
    I'm unsubscribing. Later guys
    #62
  3. Alaskan
    Alaskan Member
    Alaska
    What? This is done? I was just starting to enjoy it.
    :popcorn:
    #63
  4. lshark
    lshark New Member
    NY
    only a moderate amount of arm pressure is required to achieve the 75 ft/lb max of this Snap-on torque wrench
    #64
  5. lshark
    lshark New Member
    NY
    LOOKING AT THE FIRST PIC AGAIN, I SEE THAT THERE IS A LOT MORE THREAD EXTENDING PAST THE NUT ON THE BOLT THAT DID THE DAMAGE AS OPPOSED TO THE ONE THAT IS STILL TIGHT WHICH ONLY HAS A COUPLE OF THREADS SHOWING
    opps sorry about the caps, didn't mean to shout
    #65
  6. Big_Jim59
    Big_Jim59 Member
    Dallas, TX
    OK, I am late to the game and kind of skimmed over the ranting and raving so I might have miss this but has anyone pointed out that the nut in question is threaded way up the stud? This would have allowed fewer threads to hold in the hub. Just a thought.
    Sorry, just saw lshark's comment.
    #66
  7. lshark
    lshark New Member
    NY
    yeah thats what i saw too
    #67
  8. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    He might be using a Clymers or Haynes!
    Or possibly the book "RN Motorcycle Mechanics"
    #68
  9. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    I have nothing usefull to add and I will refrain from flaming the OP as it will obviously fall on deaf ears regardless of weather he's still subscribed or not. This thread is ammusing the shit outta me tho!!! To the OP, if you're still listening, I am glad you didn't end up on your lid!!
    #69
  10. lshark
    lshark New Member
    NY
    it ain't over till it's over !!!:wink:
    #70
  11. Skifreak
    Skifreak New Member
    Washington State
    Glad the OP was not hurt. I don't wish that on anyone.
    Of course the less obvious solution is to get a generation VFR with a single sided swingarm. Problem solved.
    #71
  12. RobVG
    RobVG Member
    White Rock BC
    In a critical application, never reuse self locking nuts. Nylocks will lose over 50% of their grip if used a second time. I don't remember how much stover nuts loose but it's a good percentage.
    Things that make your nuts come loose...
    #72
  13. Valentino Robbie
    Valentino Robbie New Member
    SE London
    Maaaan I actually gasped out loud when I see the picture of the swingarm. Whatever the cause (which the debate is still ongoing it would seem) that is one hell of a trophy you have there.
    Friend of mine changed the back wheel on a bike a little while ago, but forgot to put the wheel spacers back in, done the same sort of damage to his swingarm.
    Regardless of how it is done, and we have all done silly things mind you, glad you and the bike are ok and it wasn't an expensive problem this time around unlike some other things.
    I myself have brake disc in my garage which is wafer thin in the middle due to the rear brake being used with no pads in the caliper...might turn it into a clock...
    #73
  14. Badbilly
    Great article on bolt science. What we need now is the same info on sledge hammers although IMO and the opinions of others should include never using a sledge hammer on your nuts.
    #74
  15. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Even 'slight' over tourques can distort the surface or profile of what you bolted down.
    BZ
    #75
  16. Bubba Zanetti
    Delaware
    Since that is common sence, they probably thought there was no need to state it BB.
    BZ
    #76
  17. fredsncoma
    fredsncoma New Member
    Gardnerville, Nevada, United States
    OMG other than the OP's original misfortune and luck that he didn't get hurt this maybe one of the all-time greatest threads.
    Could this scenario be why Honda went to the SSSA on the VFR? I'm just saying.:biggrin:
    #77
  18. lshark
    lshark New Member
    NY
    i prefer my nuts snugged by hand !!
    #78
  19. tyarosevich
    tyarosevich New Member
    Seattle, WA
    Err, this is not a thread in which common sense is fully valid!
    #79
  20. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    I like turtles.
    #80
