Destroyed my Swingarm, take my advice.
Discussion in '1st & 2nd Generation 1983-1989' started by JasonWW, May 19, 2013.
  1. ridervfr
    I have a torque calibrated right-elbow.
    Love the Peter Gabriel reference above^
    Would anyone buy a used vee-hickel from the original poster?
  2. Rainbow7
    Rainbow7 New Member
    Muslim-free Queensland
    Or a torque hammer?
  3. Badbilly
    Not yet. I will after I get done weighing all my hammers.
  4. vfourbear
    vfourbear New Member
    Brazil
    Cincinnati
    Sorry bro, musta been hammered when I posted that.
  5. thx1138
    thx1138 New Member
    Perth
    To be fair to the OP he has done what he set out to do - warn against using a hammer to tighten bolts or nuts.
    I also think the OP is right - you can use a hammer to achieve very accurate torque settings.
    There are a few things you need to know;
    E=MC squared
    M Is mass of hammer (must know weight)
    C is velocity of hammer (must know speed at impact)
    which gives you E, the energy of the hammer when it strikes the spanner
    To find out the torque applied to the fastener there are a whole bunch of engineering calculations (which I remain blissfully ignorant of) to do with the length of the spanner (leverage), weight of spanner (inertia affects calculation), and possibly smaller calcs to do with follow through of strike, squareness of strike to fastener.
    I guess that with enough time and effort anything can be calculated or you can just spend a hundred bucks on a torque wrench and get accuracy in seconds with no calculations needed.
  6. lshark
    lshark New Member
    NY
    did we miss this in the original post ??? "... and when I pulled in the clutch and coasted down to a stop...." he's not only a bad mechanic...........!!!!!!!!!!!!!!
  7. jugornot
    jugornot New Member
    Bunnelevel
    Had to replace the titanium window on this beauty Memorial day. You don't touch this without a torque wrench. The window has 90 bolts torqued in 4 steps and then verified with one torque wrench. You want to see someone have a ship fit, head in the vault with a hammer. We use matco torque wrenches and replace them once a year. That is every 3 windows. I started 40 years ago rebuilding a 62 olds f85, with a 215 CI all aluminum v8 4 barrel. I used a torque wrench then and use a torque wrench now. I can get close without using a torque wrench, but for me close isn't good enough.
    That said I this will be stuck in my head next time. Link
  8. thx1138
    thx1138 New Member
    Perth
    Great song and very appropriate.
  9. Badbilly
    Tomás de Torquemada
    Tomás de Torquemada, O.P. was a 15th-century Spanish Dominican friar and the first Grand Inquisitor in Spain's movement to restore Christianity among its populace in the late 15th century.
    I think this dude invented the torque wrench.
  10. Badbilly
    That is one great looking barbeque.
  11. jugornot
    jugornot New Member
    Bunnelevel
    85Kwatt microwave.
  12. thekelzer
    thekelzer New Member
    Paradise!! Hawaii!
    [I wish I could extend the swingarm about 3". Looks nicer.[/QUOTE]
    I thought you knew what you were talking about....until I read that line. C'mon dude...REALLY? you want to extend the swingarm 3" because it "looks nicer". Nevermind it fucks the handling all to hell. You sir are a SQUID.
    I'm very happy you are ok though! You lucked out...and I'm checking mine in the garage right after this!
    If you want a long bike because it "looks nicer" then buy a long bike. Don't screw with a classic!
    Sheesh!
  13. OOTV
    OOTV Member
    For those posting comments to the OP, be advised he tuned out out long time ago...post#62 to be precise, but feel free to still comment, some of the best have come post departure!
  14. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    OR just use the old "dis will du her" smack with the Arm Strong calibrated torque hammer.
  15. Alaskan
    Alaskan Member
    Alaska
    Does that chain look a little bit dry to you?
  16. blakeo
    blakeo New Member
    Saint John, New Brunswick
    This is how my bike looked when I bought it. Very used.
    teardown 022 | Flickr - Photo Sharing!
    It's been replaced.
    Anyone want a HammerTorque(TM) Swingarm for cheap? Fits 1986 VFR 750 F and probably 1987. May fit other models with minor adjustments. Buyer to confirm.
  17. thx1138
    thx1138 New Member
    Perth
    Do you have the three inch longer version?
  18. WetSpot
    WetSpot New Member
    Ferntree Gully, Melbourne
    You're on the right track, thx1138...
    (½ E=mv^2) , we aren't converting uranium into raw energy here... :tongue: You also need to make an allowance for a portion of the 30% recoil of steel as the shank of the spanner would distort once struck - this recoil is normally a detrimental effect in the loss of energy however in this case it may act to multiply the energy applied to the stud... The Shock loading of the stud and the effect that has on the softer metal of the hub in terms of the mechanical bond can lead to weakness at this point... :smile:
  19. Badbilly
    Actually yes. often torqued but never abused with a hammer.
  20. thx1138
    thx1138 New Member
    Perth
    I thought it would be appropriate to post some pictures of my torque wrenches here.
    The ones towards the front are obviously inch pound wrenches;
    And the special Honda tool for torqueing cylinder head nuts and the valve adjustment lock nuts (next to a spare early model 1000R head);
