Do not buy K&N Wrench On oil filters: Busted on me
Discussion in 'Mechanics Garage' started by EricTrant, Mar 25, 2017.
  1. raYzerman
    raYzerman Member
    Millgrove, ON
    Apparently the lettering is not enough..... isn't that evident? Some can't read.
  2. skimad4x4
    France
    French Alps & London
    Enough is enough. Aparrently this same sh1t is still happening with their carp oil filters on other makes of motorbike..
    Why does it seem they are only going to do something to fix this design once someone is killed?
    Gator likes this.
  3. fink
    fink Member
    Nowt wrong with the design just the idiots that fit them and tighten up using the Hex. The same Hex that is only supposed to be used when removing said filter. It even says so on the effing box.
  4. Gator
    Gator Member
    Actually that is not true. I have had 2 leaks with them that were from the O ring bunching and pinching due to the outer housing of the filter being the wrong size. 1 on the CBR at the track where I almost high sided to the moon and the other on the VFR. There is a thread on 1000RR where a guy had the same problem and took a micrometer and measured a stock filter and the K&N showing in photos that the K&N is slightly off in diameter. Yes a lot of idiots do tighten the hex and stress the shitty welds but there are many failures from pinched O rings on properly installed filters. They are just dangerous POS!
  5. Gator
    Gator Member
    I think the big gushers are the HEX nut. But the failure I had at the track was the O ring and while not a gusher it did dump a lot of oil in a short period. Granted I was hammering the hell out of the CBR with near red line rpm's but that should not happen no matter what.
