Do you always ride the racing line?
Discussion in 'General VFR Discussions' started by RobVG, Sep 7, 2016.
  1. RobVG
    RobVG Member
    Seattle
    I've found if your not really going "that" fast you don't need to take the line.
    It's totally different to ride how cagers drive and breaks things up a bit. Not quite as fun though.
    There is the advantage of giving you a split second more reaction time going around around a blind corner.
    Might need that someday...
  2. RobVG
    RobVG Member
    Seattle
    Bored this morning...
  3. RVFR
    Really depends. My take isn't so much the race line as just figuring out the most efficient way around a corner, but that changes as the corners do. Open and clear sweepers vs. blind, like out of Legggett hwy 1, as twisty fun it is, man you can't tell how the corner goes, closing vs. opening up, decreasing radius vs. off camber, down hill vs up. it's hoot, but when it come to lines taken, depends on the whats happening. Yea ain't the weather just grand.
  4. OOTV
    OOTV Insider
    I'm always playing with lines and trial braking but if I'm doing a more "spirited" pace, chances are I'm taking race lines. On some of my favorite roads, I'm taking the lines I know work well for me.
  5. Badbilly
    The same applies to bicycling,skateboards, rollerblading and possible even track and field in the sprints (400 meters and below) On a motorcycle, it might be more prudent to pay attention to the double yellow than the racing line for the obvious reasons.
    Fast and slow are relative unless ya got one of them 180mph VFRs that some of the fast guys have.
  6. RotaryRocketeer
    RotaryRocketeer New Member
    OKC Metro, OK
    Solid question! I've often wondered how everybody else approaches this. I find myself always taking the fastest line. Unconsciously so, most of the time. Bike, car, truck, company car, makes no difference.
  7. Lint
    Lint Member
    Simi Valley, Ca.
    Whenever I drive or ride, I am practicing the lines that I got advised to take from David Anthony. I figure that in martial arts, you practice slow for muscle memory, then I'd do that driving/riding for the same reason. I have found it helps a lot when riding new roads, like this past ride on the 4th. Since virtually everything was new, I was focusing on how to set myself up for the correct line, as I didn't know what was around the turn. I still got caught out a few times, as those behind me can testify. But, due to a more correct line, I was able to get on the brakes hard and at least stay in my lane.
    Every day I need to learn more.
  8. 01ragtop
    01ragtop Member
    San Diego
    I never set out to use the race line, that doesn't mean I never end up on the race line, but I much prefer the late apex on Canyon roads. On roads I know, I may not use either line if there are pot holes, ripples, tar snakes, etc that will upset the bike more than being off the ideal line. On one of my favorite roads, Banner Grade, there is a back to back turn where the exit speed of the first turn is too fast for the following turn, and the area to brake while straight up is not long enough to shed enough speed to enter the second turn. If you go through the first turn on the race line, you will be inside the following turn going way too fast and you'll be over the fog line before you know it. By taking a late apex, you keep the speed down a bit, and you can hit the second turn from the outside of the turn. Yes, you sacrifice some speed by taking this approach even on turns where it isn't critical to do so, but it isn't a race anyways.
    Micheal Dunlop made a similar observation about the Isle of Mann. He noted that the best line at IOM isn't always the race line because the race is on public roads. Hearing him talk about this was an eye opener for me. That's why I take comments about my line with a grain of salt. Sometimes the comment is spot on, other times they don't know the road the way I do.
  9. Lint
    Lint Member
    Simi Valley, Ca.
    Similar. I always look for the line that will link the two turns together in the most efficient way. I almost always use late turn in. It's always dictated by the road.
  10. V4toTour
    V4toTour New Member
    Yeah, take whatever line is free of gravel, tar snakes, road kill etc...
  11. RVFR
    ^ There's that too... and other vehicles
  12. duccmann
    Glad you asked that question Rob---always thought the quickest most efficient line was the ticket--- off course + what V4 said
  13. Badbilly
    The biggest lines are yet to come.
  14. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    I know some fellas that do white lines all the time .... not the best sorts of folks ....
  15. NorcalBoy
    Im with ragtop on this one. Late apex, especially on tight, blind, turns could save your life.
  16. riprocop
    riprocop New Member
    Hemet, CA
    What line? I don't see any. I need to hang out with you guys more often so you can show me.
  17. Badbilly
    The two yellow lines are the one's to look for in a blind corner. Another indicator is that sometimes when going over the line (s) there's these little stick em up things in the middle of the road that make your front end go bumpity-bump.
    The big indicator is when ya get in the fast guy mode and ya go splat on the nose of a semi. Aka the thrill of a lifetime.
  18. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    It isn't all that it's cracked up to be, trust me, I know. ;)
    The semi truck driver needed a lesson on making corners in my case .....
    Sent from my SM-G930W8 using Tapatalk
  19. ridervfr
    Belgium
    I ride with a reserve, my tyres are worn all the way to the edges even though there are few turns were we live. The good ones are on huge over passes that are high, on more than a few occasions there have been some squids that lost control and did a super man to their deaths :rip: its about arriving alive and going on to fight another day. I raced, when i was on a track in an organized sanction, i let it hang all the way out. 100% fast as you could. Just my perspective.
  20. Badbilly
    If we all rode as well as we thought we did, we'd be on the tracks full time, whuppin ass on those so called fast guys. Notice that I mention no names of those fast guys in case I have to BS my way oot of this one..;)
