Drain hole leak.
Discussion in '6th Generation 2002-2013' started by mofo, Aug 13, 2021.
  1. jstehman
    jstehman New Member
    #s 21, 22, and 23 are the orings for the water pipe to engine block ports and for the thermostat in link 1
    Also, consider if you are that far into the vee, it might not be a bad idea to replace those hoses if your wallet allows, they are at least 18 years old? By now and they've been baking in the vee of the engine. And they May become NLA unless the 8th gen shares the same plumbing
    Sent from my SM-N950U using Tapatalk
  2. Terry Smith
  3. raYzerman
    raYzerman Member
    Millgrove, ON
    Diving Pete likes this.
  4. Diving Pete
    & was the fitment good?
  5. mofo
    mofo New Member
    Orange County Ca.
    I was considering that too jstehman.
  6. mofo
    mofo New Member
    Orange County Ca.
  7. mofo
    mofo New Member
    Orange County Ca.
    Really thank you guys for your input. Finally had time to remove the tbodies. Sure was a pain and I managed to brake a corner off, but hope this corner won’t affect performance of the air box.
  8. mofo
    mofo New Member
    Orange County Ca.
    8A28A948-D625-4CE6-B5AB-94ED11E2305C.jpeg Coolant looks good but will flush it any ways.
  9. mofo
    mofo New Member
    Orange County Ca.
    The corner I broke off.
  10. mofo
    mofo New Member
    Orange County Ca.
    17AA54F4-47E1-4276-B154-A60A9898BAC7.jpeg I think the coolant was leaking off those two short hoses. Little bit of calcium build-up and I don’t see any other damage. May be old and tired hoses.
  11. jstehman
    jstehman New Member
    Great! You're already that far, now if go ahead and do the orings for the water necks and replace the hoses.
    Then you will likely never have to do it again for a Long Long time
  12. mofo
    mofo New Member
    Orange County Ca.
    That’s the goal: to take my time and do it right the first time. I would hate to do it again any time soon.
    Thanks jstehman.
  13. mofo
    mofo New Member
    Orange County Ca.
    Making some progress with my limited time.
    Got the water ports out and gave them some TLC. Definitely the leak was coming out of the old and tired hoses.
    Hope my issues and progress can help someone else.
    Here are some before and after pictures of the coolant ports.
    CF0DFCAF-D82B-411F-8B39-B442B8DBC7CE.jpeg CF0DFCAF-D82B-411F-8B39-B442B8DBC7CE.jpeg
  14. mofo
    mofo New Member
    Orange County Ca.
    After some TLC.
    jstehman likes this.
  15. mofo
    mofo New Member
    Orange County Ca.
    The inside of the ports don’t have visible damage or pitting.
  16. mofo
    mofo New Member
    Orange County Ca.
    In case you’re still following or interested, I got a reply from yzerman corroborating that the hoses are a good fit.
  17. Camp
    Camp New Member
    Easton, PA
    Pre- As3 hoses I see.
