Draining the Cooling system questions.
Discussion in '8th Generation 2014-Present' started by bravastar1, Jun 30, 2019.
  1. bravastar1
    bravastar1 New Member
    Parker, CO.
    A year ago I caught a rock in my radiator and added some alumiseal to stop the leak since I was on a long road trip. I now need to drain and refill the system to get the excess sealant out. Has anyone done a drain and refill on their 8th gen VFR cooling system and were there any problems along the way?
  2. Vulcanator
    Vulcanator New Member
    Portland, OR
    I did one a while back. There are two drain plugs, one on the left side of the engine -easy to get to. Then there's one that's on the front of the engine-that's a pain in the ass to get to. I drained just using the left one. Make sure you have a bucket to catch the coolant-it spurts out with a bit of force. When I did mine the coolant shot halfway across the garage.
  3. Thumbs
    Thumbs Member
    Bath(ish)
    When you had the drain plug out can you remember what the gasket on the bolt was?
    Fibre washer or O ring?
    I’ve just got the coolant to do mine and can’t find the part # for the washers
  4. Vulcanator
    Portland, OR
    I believe it was a copper washer.
    Thumbs likes this.
  5. bravastar1
    Parker, CO.
    I did a drain and refill yesterday on my 2014 VFR. I too used only the left side drain which is on the water pump. You would need to remove a bunch of stuff to get to the other drain bolt. I ran about 2 gallons of water through the system before I installed the new coolant. Make sure you drain the overflow reservoir as mine had a bunch of crap in it. The total time was about 2 hours. Yes there is a copper washer that was replaced as well.
    Mad Doctor and Thumbs like this.
  6. Mad Doctor
    Mad Doctor New Member
    Utah
    How did you go about draining the overflow reservoir?
  7. bravastar1
    Parker, CO.
    I unhooked the overflow hose at the radiator neck then poured water into the coolant bottle. I had to suck on the end of the hose before it would start draining. Once it started I kept the bottle full as it drained. That flushed all the crap out.
    PetePower, Mad Doctor and Thumbs like this.
  8. Thumbs
    Thumbs Member
    Bath(ish)
    Just done mine, you were right about the fluid shooting out, I’d got a tray ready and it shot past that
    I had all the lower and middle panels off and could only see the one drain plug
  9. NorcalBoy
    I hold a funnel in front of the drain hole and direct it into the pan.
