Dropping the rear brake lever.
Discussion in 'Mechanics Garage' started by daffyduck1962, Jun 28, 2015.
  1. daffyduck1962
    daffyduck1962 New Member
    Harlow, Essex, UK
    Footrests dropped 1" bars raised 3/4"
    Comfort at last. Does anyone where I can buy an adjustable rear brake lever? I've lowered it as much as I can but still too high. This is the only issue yet to be resolved.
  2. TNRabbit
    TNRabbit New Member
    Woodford, VA
    Heat & bend~
  3. daffyduck1962
    Harlow, Essex, UK
    If I hear and bend won't it weaken it?
  4. Badbilly
    Measure twice, weld once.
  5. TNRabbit
    TNRabbit New Member
    Woodford, VA
    I did this with a bent gear shifter lever & have had no issues....
  6. LannyL81
    LannyL81 New Member
    Green Valley, Arizona
    If the 2001 has the same rear brake setup as my '97, then I can tell you how to get the pedal a bit lower without bending....but I do not know if the same or not....do you?
  7. flexiflyer
    flexiflyer New Member
    Big Illinois Cornfield
    I drilled an 1/16" hole (in a press) from the inside of the pedal (where it meets the "bracket") toward the outside, stopping with just a minimum left before it punched through. Then cut the pedal off right where it meets the bracket. Inserted a shortened 1/16" roll pin equally so the pedal was tight against the bracket. Temp installed it, rotated it to my liking and tigged it.
  8. daffyduck1962
    Harlow, Essex, UK
    Send me a pix please
  9. flexiflyer
    10-4, I'll grab one later for you. Can only show the finished pedal but its a simple fix. Edited above, it was 1/16" pin, not 1/8".
  10. Gator
    Gator Insider
    Can't you take it off and realign the teeth to a lower position? Or am I thinking of one of my other bikes?
  11. flexiflyer
    Sorry about the mess. She's down for the major inspection prior to my annual several thousand mile mental health ride. jg 012.jpg jg 011.jpg
  12. mark641
    mark641 New Member
    RAINTON, NORTH YORKSHIRE
    Gator, I think you may be thinking of the gear shift lever.
    Rear brake has a clevis on the end of the m/c push rod.
    To adjust simply slacken the lock nut, remove split pin and connecting pin. Rotate the clevis clockwise...like tightening a screw...couple of turns. assemble minus the split pin and see how it feels. Re-adjust as necessary then re-insert split pin.
    Sounds a lot but 5 mins ..done.
  13. Gator
    Gator Insider
    Roger that mark. Thanks.
