Dumped it...
Discussion in '8th Generation 2014-Present' started by rob30, Oct 1, 2016.
  1. rob30
    rob30 New Member
    Hi Folks, new here and first post. So, I purchased a new Interceptor (2014 leftover) on Friday and loaded in the back of my truck and hauled it home. It wasn't until my 20th mile that I dumped it on the right side in a low speed turn. Now, I am not a new rider. I come from dual sport bikes with 50k miles since I started riding a few years ago.
    The crash happened as I started to let the clutch out and didn't give it enough gas, it stalled as I started to lean into the turn. I was unhurt, hulked the bike back up on my own, and continued.
    I will be replacing the plastic that was scuffed. The most damage is to the upper cowl where the interceptor decal is.
    The question(s) to the collective is: It appears that I need to remove two sections of cowls on the bike to get to the damaged area. Is this going to be a huge pain? Are there any tricky gotchas? Hard to reach hidden fasteners? Fasteners I should replace if they are removed? Any components I should be checking and reviewing when the cowls are off? Thanks.
  2. 34468 Randy
  3. RVFR
    OML.. how sad, glad it wasn't worse whats that they say " Shit happens?" Now that said, welcome to the crazy house,, LOL way to go Randy, Nice of you to point the new guy off coarse ;) like he wants to remember or have anything to do with this hic up
  4. skimad4x4
    France
    French Alps & London
    Hi Rob
    I am sorry to hear about your mishap but even so welcome to the MadHouse:welcome:
    When you get time please visit the introductions section to say Hi to the rest of the folks on here and post up a photo of your VFR (pre or post your customisation is fine) - its easy click the insert image icon, then follow the prompts to select and upload photos from your computer. You may also want to update your forum profile (Forum Actions + Edit Profile) to include the specs of your bike and an approximate location City/state is fine so they appear automatically with all your posts and if you need help you may find someone nearby is willing to swing by and help - especially if you have a well stocked beer fridge:drink:.
    :focus:
    As for removing and inspecting the damaged panels, the mounting system is quite simple - a mix of: simple to unbolt hex head bolts, plenty of screws and a few of Honda's favourite plastic fasteners - the trick to removing them is (1) read the useless instructions in the handbook (2) find a small screwdriver and simply press INwards on the centre section of the fastener head which will move inwards slightly to release tension on the fastener. Finally slip the screwdriver behind the head of the fastener to ease it from the fairing.
    I have no idea what level of knowledge you have, so just in case this is your first attempt at dismantling bits from a motorbike here are a few tips. Its a good idea to have a marker pen and plenty of plastic pots or sandwich bags to hand to label and store all the small bits in as you take them off. If you leave bits scattered over the garage floor it can end in tears. (dont ask!).
    Take (get a friend to help) digital photos as you go, so you can later go back and see exactly which bits came from where. It may be several days before you are ready to refit or replace the fairing panels.
    Place a blanket on the garage floor to put the fairing down on and inspect it carefully. Take your time before deciding whether to fix or replace as minor cracks and scuffs can be plastic filled (melted zip ties) and after sanding down and preparing, a professionally repainted panel should match the rest of the bike fine. Check all the fairing mounting brackets for damage/distortion, as necessary compare with equivalent bracket on opposite side of the bike. If stuff is bent it is often better to remove the component completely and carefully (slowly) ease it back into shape whilst held in a vice.
    When you are done maybe invest in some R&G frame sliders. As you now know these bikes are quite top heavy and can be a handful at low speeds. Sliders will greatly reduce damage in tip overs or low speed slides.
    Take care ATGATT
    SkiMad
  5. GatorGreg
    GatorGreg Honda Fanboy/LitiGator
    Orlando
    Ouch, glad you're okay but sorry about your bike. If you search the forum I think I remember seeing a thread with a nice tutorial on removing the 8th gen plastics. How fast were you going roughly? What gear were you in or trying to get in when releasing the clutch lever? I've been riding for a few years now but still consider myself a newb so I still like to learn from others' drops.
  6. duccmann
    Sorry for the tip over, didn't mean to hit the thank you button
    Great advice Skimad.
  7. ridervfr
    Belgium
    Least your ok, metal and plastic can be repaired. I promise not to hit the "like" buťťön either
  8. Allyance
    Allyance Insider
    East Bay, California
    Take your time, use little plastic dishes to isolate each group as some of the hex head bolts have different shoulders and threads, hard to remember which went where. Don't force any of the panels, they interlocking tabs that will release with some wiggling.
    Sorry for you mishap, I know what felt at the time, got to pull in the clutch quickly to avoid the effects of engine braking, let the momentum of the bike help you around corner.
  9. A.M
    A.M Moderator Staff Member
    Welcome and congrats on your VFR!
    I'm sorry that happened, but know you aren't alone.
    With the great advice here, I hope you can get at what you need to.
    While you have your camera out taking photos along the way, shoot one up on here. ;)
  10. Badbilly
    Aside from what SkiMad says, don't force any of the panels whilst removing same.
  11. fink
    fink Member
    Instruction on how to remove panels are in the owners manual.
  12. Bubba Utah
    Bubba Utah Member
    Utah
  13. duccmann
    Think some of us from the older generation
    (cough cough) we all have similar stories--- I fer sure have a few, not proud but thankful I survived those years of reckless abandonment.
  14. Sniper
    Sniper New Member
    Panels are a piece of cake.
    I order parts from RonAyers.
  15. A.M
    Thanks for listing your resource. Very user friendly site.
  16. rob30
    rob30 New Member
    Thanks folks. I guess its a little frustrating knowing that I biffed it in the first 20 miles, and at the main intersection in town... Oh well.
    I appreciate the help all who have spelled out the cowl details for me; Thanks!
    We now have 210 miles together. Can't wait to hammer out some cross country tours next year.
  17. jhenley17
    jhenley17 New Member
    The bike feels top-heavy to me. 5,000 miles with it and I still get a little nervous doing u-turns. I've very quickly put my foot down a few times.
  18. A.M
    I dumped mine doing a slow u-turn on a slope while loaded down in Canada with all my gear. I just needed more practice. Just keep on it. I did think it a bit more top heavy than other motos I've ridden, but not terribly much more. I shaved my seat so I sit lower in the pan and that did help me feel more balanced. Yet I still dumped it.
    I think I read somewhere about how SOW reckoning it falls over because it is top heavy...and something about a broomstick so stay away from broomsticks or whatever it is. ;)
    Sent from my SM-G930T using Tapatalk
  19. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Damn, dude ... that sucks!!! With motorcycles, it's not a matter of *IF* ... it's a matter of *WHEN*. It happens to us all.
    Not familiar enough with the 8th gen to comment, but generally, the fairings are pretty easy to get on / off.
    Glad you weren't hurt and the damage is pretty much cosmetic.
  20. fatshoutybloke
    fatshoutybloke New Member
    Essex, UK
    Don't worry, we've all either done it or are eventually going to.
    Small tip, I find one of my smaller Allen screwdrivers with, a...er...small tip, is better at pushing in the middle of the plastic fasteners. Don't forget the four with cross-head screws under the belly pan.
    Oh, and welcome!
