Dyno results in
Discussion in '5th Generation 1998-2001' started by pap11y, Jan 16, 2011.
  1. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    damn son those are some big numbers!
  2. pap11y
    pap11y New Member
    Sydney
    translation?
    Cool. Bhp was never a priority but good to know :)
    I have made the following assessments of the chart (am I on the right track? - see below)
    It looks like there is some improvement at the 3-5k mark
    Looks like between 9-11k I'll need to hold on :) I don't see myself getting much benefit from this on the street but should be fun at the track..
    Looks like there is no point in revving past 11k as well..
    That is if I am reading this correctly.
    Does that sound right?
  3. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    definetely sounds about right to me lol
  4. tinkerinWstuff
    I'm just looking for the flat spot someone said was present in all V4's.
    Haven't found it on my chart and don't see it on yours either.
    Did you get a fuel ratio chart that tracks along with the HP and Torque?
  5. invisible cities
    invisible cities New Member
    new york
    Is the mid-range 'flat spot' based on VF engines having a 360 degree crank with a 1-4-3-2 firing order?
    (source: Wikipedia)
  6. Nitrousva
    Nitrousva New Member
    Richmond
    Maybe it's because there metric? LOL
  7. tinkerinWstuff
    Don't know. He wouldn't answer me in the thread I pulled that statement from. Think he has me on ignore like some 8yr old girl in elementary school.
  8. invisible cities
    new york
    I can see how the crank rotation and firing order can affect the HP/Torque curve but the specifics of each style are still not clear to me.
    On a side note I did get a kick out of the chart noting the VF as being a 'droner'.
  9. 02 VFR Rider
    02 VFR Rider New Member
    ok tink, you will not see any HP gains from those mods.
    What you do get is better throttle response, so I would consider it a performance mod.
  10. 02 VFR Rider
    Take a look at the dyno chart above for the 07 at 6,800 rpm, you will see the dip at the vtec trans.
    I have not seen this dip in any VFR's other then the 6th gen due to the vtec.
  11. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    :pound: lmao must be the reason!
  12. pap11y
    pap11y New Member
    Sydney
    I did not get any fuel ratio stuff. He has not sent my chart yet. I had to revert to the pic I took on my phone..
    As for the other stuff NFI...
  13. tinkerinWstuff
    It's one of those things where you probably needed to be there....
  14. NorcalBoy
    The PAIR block is a requirement for FI bikes being tuned with a Power Pommander, so you could say it is a performance mod.
  15. tinkerinWstuff
    you're grabbing at straws. you don't have to install blockoff plates to disable the system for tuning either.
    disabling the system is required for tuning carbs on a dyno as well. It's required to get an accurate reading of the combustion gasses in order to properly set the air/fuel mixture.
  16. havcar
    havcar New Member
    Denver CO
    Brother Tink, I regret to inform you that your dyno numbers have already been altitude adjusted for sea level. In other words, those graphs are only accurate whilst riding butt naked in the moonlight down Daytona Beach. Rather than adding to the numbers when you get to sea level, you'll need to deduct 15% for cruising around FoCo, and 42% should you find yourself yodeling on top of Mt. Evans.
  17. tinkerinWstuff
    The dyno is adjusted for sea level, but not for oxygen. The adjustment takes into account the tool being used at sea level. But it can't pretend it knows how much displacement the motor has and how much more oxygen it could suck in if it were a liter bike or a 600, a 32mm carbs or 40mm. The only way to really know what it produces at sea level is to have it tested there - and that's from the owner of the dyno.
    He recommended taking a road trip to Vegas where the Dyno factory is and having it tested there to see the difference.
    Sounds like a good excuse for a road trip to me.
  18. pap11y
    pap11y New Member
    Sydney
    Hi everyone,
    I have a tip for people getting dyno work.
    After getting the bike dyno'd the idle was fast. After adjusting the idle as per the manual the bike was running crap when cold.
    I decided to do some searching and found this thread:
    http://vfrworld.com/forums/mechanics-garage/29099-cold-idle-adjustment-video-00-01-a.html
    This was not adjusted correctly and once changed the bike was back to awesome "when cold".
    This is really worth knowing about if you plan to adjust your idle. I had no idea there was a cold idle adjustment.
    Thanks to the dude who posted the video. Very, very helpful.
  19. NorcalBoy
    I have a lot more experience with these things than you might think. Of course, that doesn't mean shit in the rarified air of FOCO. My guess is that you know more about what you have read, than practical experience, but that's just a guess.....
  20. tinkerinWstuff
    I have no doubt. I still believe that in most cases, people are better off leaving it alone. I don't have a problem with people removing the PAIR, as long as they really understand why (i.e. weight reduction or whatever). For every post where someone says "it's the greatest thing", there's another post that can be found where someone reported, "I didn't notice a difference."
