Dyno results in
Discussion in '5th Generation 1998-2001' started by pap11y, Jan 16, 2011.
  1. 02 VFR Rider
    02 VFR Rider New Member
    I would say on bikes w/ carbs you will see no results, FI you will.
    #41
  2. tinkerinWstuff
    so how about some proof?
    #42
  3. 02 VFR Rider
    hop on my bike and try it for yourself, I will put it all back on then take it all back off again, it does make a difference.
    #43
  4. tinkerinWstuff
    I agree that with an O2 sensor, the computer should make different adjustments to the fuel mixture if you change how much air is being sent to the exhaust system.
    I also believe that Honda engineers were likely smart enough to know this, since the system has been used for 20+ years on all the big name Jap bikes.
    So to block the PAIR would, in theory, send less oxygen to the O2 sensor, the computer says, "HOLY SHIT WE ARE RUNNING RICH" and the computer should theoretically LEAN the combustion mixture out further. Most mechanics will tell you that LEAN is damaging to a motor.
    SO, to remove the PAIR, without using a custom Dyno tune is reckless in my opinion. To tell people to remove the PAIR without telling them they need to do a custom Dyno tune is reckless in my opinion. Some people might think their bike feels "better" or more to their liking, but how do you know the current mixture is healthy for the long term of your motor?
    If someone has evidence beyond "the seat of the pants guage" then I'm all for it. I want measured proof and not back yard mechanic, I'm smarter than the Honda Engineer, proof.
    #44
  5. tinkerinWstuff
    Further -
    Since now a guy is doing a custom Dyno tune to smooth out the fueling and making sure the air/fuel mixtures are correct, why not just leave the PAIR system alone? It's well accepted that the PAIR does nothing to HP or torque. It does allow oxygen into the exhaust to burn excess hydrocarbons which is better for all of us. If the system is working as designed and doesn't impair your riding experience, then it's only good for everyone.
    So, once again, unless someone is building a race bike and stripping every excess ounce off the bike, I believe it's a waste of time and energy to mess with PAIR valve removal. Do a custom Dyno tune and leave it alone. Don't be cheap.
    #45
  6. 02 VFR Rider
    I have run air fuel gauge on it as well as when I installed my chip and well within the correct range
    #46
  7. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    "In 2000, Honda updated the fifth generation VFR (RC46) with a catalytic converter, oxygen sensors, and an EFI system that would enter closed-loop mode under highway (cruising) operation." (wikipedia)
    the o2 sensors are only used during light throttle cruising. the pair valves only open during decelleration. removing any of these trivial efi compents isnt going to damage anything. it will only "if done properly"
    result in more drivability.
    #47
  8. tinkerinWstuff
    if it's only open during deceleration, then how does it's removal translate into improved drive-ability?
    And citing Wikipedia as a source is no more official or reliable than reading it here.
    #48
  9. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    ... dunno i guess goin on an off throttle, the o2's comin on an off the pair opening and closing, can turn into surging. i did the o2 eliminators before the pair block, so i didnt get anything out of the pair block off (but a pound or two weight savings and less clutter).
    #49
  10. 02 VFR Rider
    then why do they dis connect it when dyno tunning??
    #50
  11. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    they disconect the pair vales during tuning so it doesnt skew the air/fuel results.
    #51
  12. tinkerinWstuff
    They don't know any better?
    because maybe it's also open at idle as I've also read at VFRW?
    Hold over from the carb days when it was open at idle and just off idle and would mess with the tailpipe dyno sensor?
    because the tailpipe dyno sensor is at the back of the can and not up by the O2 sensor in the manifold (delayed reaction to the dyno reading of what's really going on vs. residual oxygen still being flushed through the exhaust system)?
    #52
  13. pap11y
    pap11y New Member
    Sydney
    When does this argument become redundant?
    Wanna do block off cool.
    Don't wanna do it cool.
    I did it and to me there is no noticable difference. I didn't do it for performance I just wanted all of the extra pollution crap removed. That being said I made a few changes so its hard to know exactly what did what.
    If I was unhappy I would just re-install it. No biggy.
    As it is a non-destructive easily reversible mod whats the difference?
    The air box snorkel mod has little/no noticable hp gain but I think it was one of the coolest mods I did. Other people think its too loud.
    Its all such a personal thing, why would we think there is a definitive answer for each mod?
    #53
  14. tinkerinWstuff
    pap - this isn't about you dude. It's winter and we've had this arguement across three different threads this week. It's just what we do when we're bored.
    #54
  15. pap11y
    pap11y New Member
    Sydney
    Fair call :)
    :) Fair call. Enjoy
    #55
  16. bluevfrrider
    bluevfrrider New Member
    North East England
    It`s my line of thought if you want your bike to go faster get a faster bike RRX fireblade?
    If you want your bike to go better up grade the suspension and fit sports tyres
    must vfr rider use sports tourig tyres my self inclueded
    It takes a good man to get the best out of a VFR I no I can`t
    #56
