Please help. I manually rotated the exhaust servo just to hear what my baby would sound like, but now I get a error code 34 that I can't clear and a small whining noise from under the left front seat/tank area that may be the fuel pump. Is there a diy to fix or do I need to take her in to my dealer. Thanks in advance.
Put the cable positioner back where it was. Do this while the power is off. Then turn key on. Should turn the servo and the code disappear. If you want to hear the bike without the flapper, With bike off turn serve far enough to remove cable. Then move it back to original position. Turn on key start bike. Better sound no fault codes. You also might try removing the peace sign part of the bracket.
